Harbor Freight Sand blaster opinions
- mdscott
Harbor Freight Sand blaster opinions was created by mdscott
Harbor Freight Sand blaster opinions, anyone have one. the lage one, i had the tabletop one and it leaked really bad.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
22 Jan 2018 16:54
- Pillsbury
Replied by Pillsbury on topic Harbor Freight Sand blaster opinions
The big one is pretty good but throw the gaskets they give you in the trash & either buy good weather sealing strips (hardware store) or use silicon on all the edges you were going to use the gasket on.
1970 DT1-C Street tracker
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1966 Triumph Tiger Cub
1947 Mustang
1974 Suzuki TC185
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1947 Mustang
1974 Suzuki TC185
22 Jan 2018 17:43
- david.hunter
Replied by david.hunter on topic Harbor Freight Sand blaster opinions
Drill a hole in it and stick the shop vac hose in there while blasting
22 Jan 2018 18:20
- whymee
Replied by whymee on topic Harbor Freight Sand blaster opinions
I have the HF media blaster (40# floor model) and their largest one "Industrial Blast Cabinet". Also a pressurized blaster for outside use.
I assume you are asking about the 40# floor model (around 200 bux) My random thoughts...
The above posters are correct. Use silicone on assembly of the 40# floor model. For what it costs, you cannot beat it. It does use consumables such as blasting tips, mylar window protectors etc. The light sucks. I replaced it with 2 florescent lights.
You can use a shop vac ( it has a port for one) but the vac will not last. Abrasive makes its way past the filter & eventually destroys the motor. Happened to me. Just be aware of this fact. You must use some sort of filtration to pull air out of the cabinet. You are forcing air in and that air will come out with abrasive in it. If you do not filter, you will find abrasive all over everything around the cabinet. Plus if you don't, you cant see a damn thing.
Get your consumables from TP tools. Tell 'em Stan sent ya. I also get my media from them. Some sort of mix, can't remember what it is right now. If you need to know, let me know.
Speaking of filtration. You will also need to filter the water out of your air source (compressor) This unit needs dry air.
If you have specific questions, ask away....
1972 Yamaha LT2 100
1973 Yamaha RT3 360
1974 Yamaha TY250
2018 Husqvarna TC250
2018 Pitster Pro LXR190
1983 Honda CR480
1983 Honda CR250
1983 Suzuki RM250
2017 Yamaha FZ-10
1997 Honda PC800
1973 Yamaha RT3 360
1974 Yamaha TY250
1983 Honda CR480
1983 Honda CR250
1983 Suzuki RM250
2017 Yamaha FZ-10
1997 Honda PC800
22 Jan 2018 19:04
- FrankC
- Solution Contributor
Replied by FrankC on topic Harbor Freight Sand blaster opinions
Reminds me of a funny story...I think I may have encountered one of those leaky harbor freight blasters. It was a table top I am guessing. Got it off a move I was doing for this gentleman. I was very happy to have it, but I had no air compressor. So that thing got moved around my garage for about 2 years with wifes furniture, friends furniture coming in and out. Father in laws stuff. You get the picture. I then had it on the top of my motorcycle parts storage rack. Well, one day I had to move it again, and it was loaded with about 2 inches of aluminum oxide. Started to slide it down and from out of no-where I got a face full of that dirty gritty stuff. On top of that a bunch fell in the back side of this hugh Sony Trinitron T.V. Those you guys might remember are fairly heavy. Sp-ent about 2 hours trying to get that grit out and still ended up having to throw the T.V away. I just grabbed the sand blaster and put it out on the curb. No way was I going to keep it after that. About 1 minute elapsed a guy stopped with his pick up and looked horrified that I was leaving it for the metal guys. I just said IT's Yours.
22 Jan 2018 19:08
- Papawhellie
Replied by Papawhellie on topic Harbor Freight Sand blaster opinions
You can get a USA mfg. blaster for about 700.
www.texasblaster.com/?gclid=Cj0KCQiAtJbT...iTpsvSkaAiuZEALw_wcB
22 Jan 2018 19:10
- bluntz465
Replied by bluntz465 on topic Harbor Freight Sand blaster opinions
If you have a pressure washer you might have a look at the kit to convert it to a wet blaster general less than 60 bucks and no more dust.
1982 Yamaha IT465J
1982 Yamaha IT465J
22 Jan 2018 19:51
- mdscott
Replied by mdscott on topic Harbor Freight Sand blaster opinions
Thanks for all the reply's, I would love to have a media blaster, but the problem is the space. I can leave it outside and covered is really my only option. There's a couple of youtube videos how to modify, mostly for sealing and lighting. One guy converted and sandblast cabinet to a soda cabinet.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
22 Jan 2018 21:21
- MACE6772
Replied by MACE6772 on topic Harbor Freight Sand blaster opinions
We have had one at work for about 5-6 years. ditto all of the above info. Speaking of consumables, don't forget to add a new gun to the list.What you spend in sand and all of the upgrades and the consumables in 5 years will be more than you paid for the machine. Upgrade first to a better machine. One of my previous jobs we had a Tip Mfg. cabinet. very nice easy to get parts. Every part was available. Start with something better. Good luck with your next project. Keep the pics coming.
16 Feb 2018 12:09
- FrankC
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=302634075895&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
