Life after meltdown
- msavitt
- Topic Author
Replied by msavitt on topic Life after meltdown
Okay - took a break from work and pulled crank into left side case, puller worked nicely
I am 100% sure I got all the shims etc in correct location so ignoring this can you endurologists please look at shift fork location? I have the shaft with the one shift fork engaged in the center groove of the shift drum with the long side facing the right side case since it carries shiftware on outside of right side. I have shaft with two shift forks engaging outside shift drum grooves.
Does this orientation look correct? I am 99.3% sure but thought I would ask in spirit of avoiding self-mutilation
13 Jan 2021 12:40
#11
- msavitt
- Topic Author
oh and one more thing
the crank had a single shim between crank and bearing on clutch side, but not on the magneto side
this is the way I found it upon disassembly and therefore how I planned to put it together since I do not think cases have been previously split. However, I do not see shim on Partzilla so asking to be sure, thanks all
13 Jan 2021 13:29
#12
- Jack
- Content Contributor
Replied by Jack on topic Life after meltdown
Looks right. Here's a pic of what mine looked like just after splitting case and before I had mussed with anything in the tranny so this should be correct. It's a view of a right side installation and your's is the opposite so kind of backwards to look at but shows which forks engage which slots.
On the crank shim, I couldn't find one on mine but didn't think to look for one until after I'd carried it over to the house and back once so can't be sure if there wasn't one there before. I installed it with out one but keeping my fingers crossed that it isn't needed. If your's had one I think I'd put it back in there.
13 Jan 2021 18:04
#13
- msavitt
- Topic Author
Thanks Jack!
On the Kickstarter, did you preload spring 1 turn, which seems logical to me, lest I have a limp lever
13 Jan 2021 18:33
#14
- Jack
I looked for and couldn't find any info on preload but when I experimented a bit I felt trying to wind it more than one turn would risk breaking the spring.
13 Jan 2021 18:42
#15
- msavitt
- Topic Author
So you did one turn?
I think that makes sense
13 Jan 2021 19:32
#16
- msavitt
- Topic Author
So your stuff is in right case half? Or am I entirely backwards!?
13 Jan 2021 19:34
#17
- Jack
Yes, the pic I posted shows the gears installed in the right side, that's the way it came out when I split the cases. You can install from either side though.
13 Jan 2021 19:59
#18
- Jack
Actually it was a bit less than one turn if I remember right. I turned it just far enough that the spring tension would pull the dog back into it's slot. I don't know if that's how it should be done but I couldn't figure out any other way to do it and it seems to work. To wind it any tighter I'd have had to go another complete revolution which I felt risked damaging the spring. It would have been extremely tight. I think this is correct but I'm not 100% sure so don't take my word on it. Maybe someone more knowlegeable will speak up and we'll both learn something. How are you preloading the spring? Are you using the kick start lever like I did?
13 Jan 2021 20:11
#19
- msavitt
- Topic Author
I played around some more
For me it’s either ~1/3 of a turn or 1 and 1/3 which is way too much. So I preloaded 1/3 and mocked things up by installing gear, clip, washer abs side cover so I could stroke kick lever and be sure that the thingy that goes under the guide held on by the three bolts with locking tabs in fact would find it’s way home which it did.
I am still waiting on parts and Yamabond 4 so I am going to chill until I hopefully get more expert inputs!
14 Jan 2021 00:39
#20
