75 DT125 Oil injection delete
  • drewb3739
  • drewb3739's Avatar Topic Author
75 DT125 Oil injection delete was created by drewb3739
I am rebuilding a 1975 DT125b into a scrambler. I'm getting rid of oil injection for the looks of no oil tank and because I'll be running a lectron carb and the stock throttle cables don't work with that carb without modification. I understand how to block off the pump and remove the gear but how would I go about blocking the hole in the cylinder where the oil in injected? Could I just replace the banjo bolt with a normal bolt? Anyone have expirence with this?
01 Nov 2019 21:12 #1
Replied by sagetree33 on topic 75 DT125 Oil injection delete
ya just put a short bolt with same threading and a fiber washer it can take high heat
ive done that and i run 40; to 1 worked great
01 Nov 2019 22:47 #2
one more thing was going to say is if you run any richer than 40 to 1 it could efect that
carb?
01 Nov 2019 22:54 #3
