The next project found abandoned on a ride
- Delcowizzid
Replied by Delcowizzid on topic The next project found abandoned on a ride
Had to repair a fork staunchen electrolysis ate away a portion of it other one isn't as bad. So I'm going to paint them with blue anodized looking paint and it will just look like a 94 Kdx200 with factory upside downs hahaha
- shyted
Replied by shyted on topic The next project found abandoned on a ride
Yes, i like reading this .
The following user(s) Liked this Post: Delcowizzid
21 Aug 2020 13:26
#22
- Delcowizzid
There will be more to read and see don't you worry haha
22 Aug 2020 04:52
#23
- Delcowizzid
I think this colour is perfect after a quick test shoot
23 Aug 2020 15:25
#24
- Delcowizzid
Just got my stripped kips valve back from the engineer man he's good for things like this welded the missing teeth and rehobbed the teeth back on just a small amount of fettling with a fe and some wet and dry and she's good as new for $40nzd a new set in steel was around 300nzd and NOS alloy are non-existant haha
The following user(s) Liked this Post: MarkT, 2fishkev, Snglsmkr, Pete-RT1
30 Aug 2020 23:51
#25
- Delcowizzid
Smooth as butter
30 Aug 2020 23:54
#26
- Delcowizzid
New rear brake disc arrived just need to get 6 new bolts cause this one has flat holes old disc took countersunk bolts. Front pads arrived too and a Kx250 rear spring to try stop some sag
02 Sep 2020 02:56
#27
- mdscott
Replied by mdscott on topic The next project found abandoned on a ride
How’s the rear shock condition, my 200 and 220 both needed rebuilding. One needed sealing and both were low on nitrogen. I’m fortunate to have a local guy that works at home, he does a lot of suspension work for local racers. Great guy.
www.rothracingmx.com/
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
03 Sep 2020 07:42
#28
- Delcowizzid
New shiney bits kx500 front and rear fenders.
New bolts and brake disc is on
Huge list of parts ordered just slowly dribbling in
Just bought 3L of fork oil to refill the fronts and the rear was in working condition so just clean it out flush it and refill with oil and refill it with nitrogen at work
- Delcowizzid
Gave the dt250 an oil change too was a bit overdue
04 Sep 2020 03:30
#30
