SC500 fires but will not start
  • stwsam
  • stwsam's Avatar Topic Author
SC500 fires but will not start was created by stwsam
I am at a high level of self-inflicted frustration.  1973 SC500 which was running fine except would not idle well. Re-checked carb, made are sure all jets were clean and clear. Running factory spec 80 pilot and 400 main. Correct needle in middle position. Bike will fire but not start. I have checked and rechecked carb jets and float bowl level. Replaced needle jet. Set timing to factory 2.7 mm btdc. Re-checked this numerous times.  New plug, change plug etc.
Checked spark coil and cdi ohm values and all in spec(oem cdi.)  Replaced flywheel crank seal for good measure as it was suspect.  Just removed decompression valve, cleaned, new o-ring and crush washer.  With compression guage cylinder is pushing near 120 psi.
 Checked kill switch.  I simply cannot get the bike to start.  I have been fiddling with two strokes since I was 13. I am 69 and completely baffled.  I feel like it is something simple.  Please for the love of Pete, someone steer me in the right direction.
fuel, air, spark, compression. it "ain't " that complicated!"
Last edit: 29 Nov 2026 18:02 by stwsam.
29 Nov 2026 17:53 #1
