Removing crank seal help
  • bhepp15
Removing crank seal help was created by bhepp15
How do I get this golden metal part out nicely and or does it come out with seal? Stuck at this point right now
04 Apr 2022 15:38 #1
Replied by JGersh on topic Removing crank seal help
 i use a few drywall screws and a slide hammer…
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
The following user(s) Liked this Post: JayB, none_of_my_bikes_run
04 Apr 2022 15:58 #2
  • bhepp15
Replied by bhepp15 on topic Removing crank seal help
I am thinking I have the wrong seals then as I do now have a replacement of that metal part, shoot.
04 Apr 2022 16:02 #3
The gold metal is part of the seal. Punch a small hole in the metal, thread a wood or drywall screw in a few threads and hook the head with the slide hammer. A few slides on each side will pop it right out.
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
04 Apr 2022 16:15 #4
  • bhepp15
I would assume my new seals need also have the metal part as well?
04 Apr 2022 16:18 #5
  • bhepp15
I notice that all the other ones online don’t have the metal part either so I assume either you don’t need it or you reuse the one with holes in it? Sorry I’m just a little confused here
04 Apr 2022 17:00 #6
It’s part of the seal. Many replacement seals will be all black.
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
Last edit: 04 Apr 2022 22:07 by JGersh.
04 Apr 2022 17:28 #7
  • bhepp15
Haha I must have been thinking about putting it on backwards
04 Apr 2022 18:44 #8
Before removal….
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
04 Apr 2022 18:52 #9
  • bhepp15
Which direction? Haha the manual says markings go out so I’m assuming the “plate” side faces out but I would hate to be wrong. Is this orientation correct? Only reason I’m second guessing is because the spring would now fade crank but it did not in the original.
08 Apr 2022 20:13 #10
