Clutch lever stiff on DT and RT engines
Replied by mx360guy on topic Clutch lever stiff on DT and RT engines
Wow! A replacement piece for the nylon thread! I was about to give up on my DT3 project because of the clutch actuator. I don't have the skills or the tools to do the cover mods that I have seen. I hope this will work.
I too suffer from the stiff clutch and throw of the actuator..I will report when I get it installed.
The following user(s) Liked this Post: Bigdog302, RT325, Gr8uncleal
28 Jul 2021 08:58 #11
Replied by KennyV on topic Clutch lever stiff on DT and RT engines
Has anyone actually installed a new brass piece on the actuator shaft? I'm curious as to how it's actually fastened to the shaft. I'm assuming a press fit over the spline shaft?
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
29 Jul 2021 12:35 #12
I ordered through KDI but the eBay sight said that they come with instructions. I am assuming the KDI unit should come with the same instructions.  I have found that the orientation of the threads is important to get the proper rotation/push of the rod.  I have several actuators; all with split nylon that seem to have different amounts of rotation. I think if they split, they loosen up on the shaft and slip a little thus changing the amount of rotation. Dang I really want to get this problem fixed!
29 Jul 2021 13:32 #13
Thanks, mine is still good but I know it's only a matter of time so I think I'm going to order one. I don't want to hijack the thread but this is all good info.
71 Z50 Minitrail
21 CRF300l Rally
29 Jul 2021 13:48 #14
Replied by JGersh on topic Clutch lever stiff on DT and RT engines
I spoke to Dave Kolbo about the installation and he confirmed that the actuator comes with instructions on how to install and orientate properly. I will be ordering one soon.
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
The following user(s) Liked this Post: 2fishkev, Bigdog302, KennyV, Super90
29 Jul 2021 18:36 #15
