1971 RT1 Woodruff Key
- ckjacks
1971 RT1 Woodruff Key was created by ckjacks
Does anyone know the dimensions for a 1971 RT1 Woodruff Key? Thank you!
26 Dec 2021 12:52
- Capt.Dave
Replied by Capt.Dave on topic 1971 RT1 Woodruff Key
Buy a correct yamaha key.
The following user(s) Liked this Post: Swoop56, Pedalcrazy
26 Dec 2021 12:57
- Pedalcrazy
Replied by Pedalcrazy on topic 1971 RT1 Woodruff Key
What Capn said. Done.
26 Dec 2021 13:42
Replied by RT325 on topic 1971 RT1 Woodruff Key
or just carve one out of a thick washer with the right curve. On my lawn mower--alloy key--i cut one from the corner of a yamaha head steady or front engine mount from an IT250 i think it was. Mind you i'm running out of corners as broken it 3 times hitting a tree root. Saves the crank getting twisted though, Chinese ohv motor with a heavy steel flywheel. If ya taper is good you could make an alloy one if easier because "in theory" the key is only to locate the flywheel. But of course often people don't do them up near tight enough &--broken key again. On my TT250 i experimented with advancing the flywheel so had No Key & never caused a problem but crank & flywheel taper were perfect. Mind you i 'do' overtighten things. Do it up till it strips then back it of a bit lol.
26 Dec 2021 14:10
- ckjacks
Replied by ckjacks on topic 1971 RT1 Woodruff Key
Thanks for everyone's help!
- ckjacks
Thanks, Dave and Pedal. Probably good advice, just looking to save some time.
26 Dec 2021 16:43
I guess ya not in the UK but just saw this by googling.
yambits.co.uk/rt1-flywheel-woodruff-key-p-30256.html
26 Dec 2021 16:45
- ckjacks
Hey RT, I had an old key that was close and started grinding on it but thought it might be futile. Yea, good point about not REALLY needing it except for alignment. As far as tightening, would you go 10% over spec on the torque??
26 Dec 2021 16:47
- ckjacks
No sir, USA.
26 Dec 2021 16:48
- msavitt
Replied by msavitt on topic 1971 RT1 Woodruff Key
I am not a Yamaha expert but the fit of the woodruff key is perfectly line to line with crank and flywheel and made from some pretty nice steel. Costs way more to manufacture than a washer stamped from 10xx carbon steel, I assume the engineers did this to remove any play that would otherwise damage crank and flywheel. Personally I would get proper key and torque to spec.
