Final assembly
  • principal282
  • principal282's Avatar Topic Author
Final assembly was created by principal282
Today...head on, flywheel tightened down,  exhaust on, etc.
122 lbs compression
a beautiful blue spark
Clean up and put away crap...look for the doggone missing carb nut @^$&$*$...it's not in the crank, I promise....
​​​tomorrow,  slap on fuel tank and cross fingers...
05 Oct 2021 16:44 #1
Replied by Pedalcrazy on topic Final assembly
That’s super exciting that you are so close. I couldn’t sleep waiting for tomorrow to come! I am just a little concerned about 122 PSI.  Better numbers might be 130 or higher but it will run!
05 Oct 2021 18:59 #2
  • principal282
Replied by principal282 on topic Final assembly
I would have liked 130 too...I probably shoulda went with the bore out and 1st oversize,  but so it goes. It should run okay. I'm not ripping up a racetrack with it....
05 Oct 2021 19:21 #3
Replied by MarkT on topic Final assembly
You're fine.  Looking forward to you getting it running!
The following user(s) Liked this Post: RT325, principal282, adguy2112
05 Oct 2021 19:26 #4
Replied by Sneezles61 on topic Final assembly
I rigged up a 4' step ladder next to my bike.. an extra length of gas hose and started it without the tank on the frame... Just in case there was something to fix before I did mount the tank... Removing and re-applying really seems a pain in the bum...
Its been fun following yer progress.. lumps and all!
Sneezles61
06 Oct 2021 06:07 #5
  • principal282
1,  It started and ran like a champ.
2. Smooth running for a bit. (I went easy to just warm it up)
3. 2nd fouled plug in a short while...I have several new ones at the ready
but 4. my doggone battery was dead within 5 min (no accessories or lights on)...
so on the charger.  But I am optimistic.  Why would it foul plugs so fast?
It sounded SO NICE out of the gate....
06 Oct 2021 16:14 #6
Replied by RT325 on topic Final assembly
Battery won't affect running--not related. Not sure about fouled plugs but are they oil fouled or something bridging the gap. don't have gap too wide, like 24thou max & 20 min at this stage. & most important is to have the flywheel tight. I know i harp on about that but we get a lot of flywheel keys broken on this forum.
06 Oct 2021 16:31 #7
  • principal282
Will it affect starting?
I will double check the flywheel.
06 Oct 2021 16:35 #8
  • principal282
Lost 20 lbs compression...something not right
06 Oct 2021 18:02 #9
Post #8--no, nut tightness won't affect starting but if it shears off the crank key then yes it sure will. Likely kick back or worse. But you'd soon know because if it happened riding down the street it'd start running like a hairy dog & probably not start once stopped. Just a point i like making about tightening it fully.
06 Oct 2021 21:45 #10
