1965 YM1 Gas tank petcock
- sgarvin0711
1965 YM1 Gas tank petcock was created by sgarvin0711
I need to clean out the gas tank and eventually get it painted. How do I remove the petcock?
06 Aug 2020 17:14
- swm
Replied by swm on topic 1965 YM1 Gas tank petcock
Remove threaded bowl, remove round strainer, remove 3 JIS screws - DONE.
06 Aug 2020 18:29
- sgarvin0711
Replied by sgarvin0711 on topic 1965 YM1 Gas tank petcock
Thanks! Just what I needed. There are 2 pieces of rubber... 1 is an O-ring under the bowl and one is under the valve handle. Both seem to be in excellent condition, but should I replace them just based on their age?
11 Aug 2020 13:16
- swm
Yes, I always replace since 55 year old rubber may not seal well. I also replace o-ring on top of fuel petcock & banjo bolt washers. YDS Parts in UK has quality reproduction parts.
Good luck!!
www.ydsparts.com/yds3ym1chassis.htm
Fuel filter if needed:
11 Aug 2020 15:56
- sgarvin0711
You are my new best friend!
Just curious. Why replace the ones on the banjo bolts? They are hard and don't move. Can they wear out?
Should I also replace the strainers if they also seem to be in good order?
12 Aug 2020 15:13
- swm
I replace banjo bolt washers as they harden over time which can create another opportunity for fuel leak.
If strainer is not damaged I'd reuse it.
12 Aug 2020 18:53
