Piston critique
- yamahahaha
Piston critique was created by yamahahaha
Got this as a parts bike... What can be said about what was going on with this piston?
09 Jul 2020 16:38
- LongStride
Replied by LongStride on topic Piston critique
Rings stuck? not seeing damage except for moisture, those rings look stuck
2ET703 Central Texas
09 Jul 2020 17:06
- yamahahaha
Replied by yamahahaha on topic Piston critique
When I got the bike (Florida bike) hence the moisture...The piston was stuck due to moisture/rust....I did not think to see if rings are stuck...Will need to check
09 Jul 2020 17:14
- apex
- Content Contributor
Replied by apex on topic Piston critique
No need to check if they're stuck...they ARE stuck. Typical from sitting, going through seasonal/humid heat/cool cycling. Maybe you can free them up with some heat and a pick? Piston doesn't look too scored, that could cleaned up, crosshatch sand the cylinder...it will run.
Allrighty Then
09 Jul 2020 22:20
- yamahahaha
What is the best method for cross hatching the cylinder? I have one like the one shown. Also what oils can be used for lubrication?
www.napaonline.com/en/p/BK_7769221?cid=p...7QqgRt8aAsCUEALw_wcB
- yamahahaha
Will that suffice?
10 Jul 2020 13:30
- yamahoper
Replied by yamahoper on topic Piston critique
I like using a ball hone 3 1/2" for 360 400 bore
You can use the 3 pad type , just be very careful at the bottom an around the ports that you don't have it catch
10 Jul 2020 13:53
- yamahahaha
Thanks and any special type of oil or can I use something like MMO or Kroil etc
What grit number do you recommend??
- yamahoper
Mine is a 240, most I've seen are ether 220 or 240 .
I use cheap 2 stroke oil for lubricating the cylinder during hone. Clean real good with brake clean ( the ports too). Blow off with compressed air. Rub down with 2st oil and paper towel. Clean gasket surfaces with alcohol, Assemble
10 Jul 2020 17:02
- yamahahaha
Thanks for the help
10 Jul 2020 18:06
