Regulator installation
Replied by alex.hutchison on topic Regulator installation
Thanks TerryM... This is my train of thought, but needed someone else to confirm
I'll hook up the battery and run the bike, see what volts I get then... Was a bit concerned that the previous owner may have converted to 12v
11 Mar 2018 01:42 #11
  • Rexs Speedshop
  • Rexs Speedshop's Avatar
  • Supporting Moderator
Replied by Rexs Speedshop on topic Regulator installation
If its got a 12 volt winding, don't try and regulate it to 6 volts, it will likely burn out.
Electronic Ignition Design & Manufacture*12 Volt Conversions*Electrical Parts*Generator Rewinds & Overhaul
11 Mar 2018 15:10 #12
Replied by JRunk31 on topic Regulator installation
I’ve got a 71’ CT1 175 and plan to hook up a regulator rectifier. Did you ever post that pic? I’m certain my bike doesn’t have one stock but would love to see your wiring with the yellow/white wire. Thanks!
08 Sep 2022 00:44 #13
  • Rexs Speedshop
Sorry we don't have the wiring diagram for your bike.
Generally if the generator is so low output not to have been fitted with a regulator, fitting one will reduce the output to nearly nothing.
08 Sep 2022 00:53 #14
