1975 DT 125 Battery
  • jeffshaw
  • jeffshaw's Avatar Topic Author
Replied by jeffshaw on topic 1975 DT 125 Battery
Thank you for your help! I will read through your post carefully and look at the diagram. I was hoping I could buy a battery cable kit that would come with the fuse so I could just hook everything up. I was also hoping that there would be some obvious artifacts on the bike where a battery was connected before. Unfortunately I haven't been able to find such a kit online, and I don't see where the old wire were connected. I'll probably have to piece something together from scratch. If someone could take a bunch of pictures that would be very helpful. I could provide an email address if you are unable to post pictures. I may be making it harder than it is.
08 Sep 2022 07:19 #21
Replied by Yamadog1974 on topic 1975 DT 125 Battery
Thank you for your help. Sure would like DEFINITIVE PICS
Since you have LIve Juice on all these connections!
08 Sep 2022 07:47 #22
I got the 1974 Yamaha DT125A running and wired correctly thanks to the last pic posted on here and the wiring diagram for the DT125A/B The picture he shows does not show the opposite end of wires , but i realized that`s the way bike was when I got it, with a big Yellow wire with glass fuse inside . So all you need is a heavy red wire from battery to starter relay. then looking at the last pic posted ,wire just as it shows with a red wire with 20 Amp fuse in it from single female receptacle to double female receptacle, where you have red male voltage regulator wire plugged in also!
13 Sep 2022 09:28 #23
  • jeffshaw
Nice work! I may have some questions for you soon.
13 Sep 2022 09:30 #24
e-mail me at This email address is being protected from spambots. You need JavaScript enabled to view it. for a great pic of wiring and 20 amp mini-fuse I added after soldering male bullet connectors to it!
18 Sep 2022 09:40 #25
