DT400B Twin Shock Silencer
  • Jammyyammy
  • Jammyyammy's Avatar Topic Author
DT400B Twin Shock Silencer was created by Jammyyammy
Hi,
My silencer / baffle is the ‘old type’ (small pipe outlet) shown in the attached partzilla diagram.
There is no sound deadening material inside the silencer / baffle at the moment.
How does it fit? Do I just line the inside of the silencer / baffle with it? How does it fit in place without collapsing?
Is it obvious how it fits?
Is there a video to watch?
Last edit: 19 Dec 2021 13:22 by Jammyyammy.
19 Dec 2021 12:55 #1
Replied by MACE6772 on topic DT400B Twin Shock Silencer
If you have the short baffle (marked on the diagram as "old type"), then you cannot repack the silencer, unless you would like to cut it open at the welds. If you had the "long baffle" you could repack that quite easily. Maybe some of the elder statesmen of the forum could tell us what year bikes had the long baffle. I know that my 75s have the short baffle.
19 Dec 2021 14:55 #2
  • Jammyyammy
Replied by Jammyyammy on topic DT400B Twin Shock Silencer
Hi - thanks for the info. Mine is a 1975 also.
I presume long baffles are near impossible to buy? Do the long baffles open up somehow to fit the packing material inside?
19 Dec 2021 20:48 #3
Long baffle fit into it's own special housing. You would have to find the whole assembly. Short baffle exists because "long" part is now permanently welded inside of 1975/76 silencer housing.
Last edit: 16 Jan 2022 13:11 by MACE6772.
20 Dec 2021 05:38 #4
  • Jammyyammy
Bit of a long shot here….., probably too long….., but has anyone ‘converted’ the ‘old type’ of silencer/baffle for a DT400B twin-shock into the ‘new type’, so that it can be packed with sound deadening material?
I presume something could be made (steel tube, bit of welding/cutting) and inserted into the existing ‘can’ ?
The problem is that I don’t know what the finished article would look like, so don’t really know where to start on this one. Any ideas???
Last edit: 25 Apr 2022 14:34 by Jammyyammy.
25 Apr 2022 14:33 #5
