In search of DT360 right side crank seal
- nealbob
In search of DT360 right side crank seal was created by nealbob
I just introduced myself a few minutes ago so I thought I should post this in a differnt catagory.Does anyone know a possible source for part# 93103 38086 00.Alas, I have high pressure at the oil cap hole while kicking over and no start with good spark and fuel present.
03 Dec 2021 12:17
Replied by MarkT on topic In search of DT360 right side crank seal
Check with Enduronut or DEET.
03 Dec 2021 12:20
Replied by Gr8uncleal on topic In search of DT360 right side crank seal
If no luck with EN or DEET, there are some on fleabay.
A good quality bearing supplier might also have them - see attached link to a company in the UK. I would be interested in the experts' views on using an aftermarket part such as this.
Search Results: - Simply Bearings Ltd
03 Dec 2021 12:32
Replied by RT325 on topic In search of DT360 right side crank seal
Not common for the 360 to push the crank seal out but 'does' sound conclusive in your case. You could set the piston at the bottom & pressurize the trans breather tube & see if you can hear it down the plug hole. Or carb & reed block off & piston at top, that'd work & hear it via the inlet. I've never needed to do that but just clutching at random ideas.
- Schu
Replied by Schu on topic In search of DT360 right side crank seal
"Not common for the 360 to push the crank seal out"
I was surprised when it happened on my DT360. Surprised because it actually bent the seal retainers!
The following user(s) Liked this Post: apex, MarkT
03 Dec 2021 16:29
- msavitt
Replied by msavitt on topic In search of DT360 right side crank seal
careful about buying transmission seals from buzzards that put these on eBay next to a Yamaha label
The following user(s) Liked this Post: Enduronut, MarkT
03 Dec 2021 18:02
An event like SCHU in post #5 can happen if there's an explosion in the crankcase or even a belly full of fuel & a good kick. Or ignition crank key broken & timing then anywhere but right so fires up whats in the crankcase & seal escapes under pressure. Anyway--new seal & onwards & upwards. Hope the left one is still i place but right escaping probably saved the left side.
03 Dec 2021 19:02
- hackman101
Replied by hackman101 on topic In search of DT360 right side crank seal
@Msavitt, I bought a set of gaskets for my 73 MX250 from Bike Buzzard. I have not opened the pack yet, and I have had them for a while now. I presume there may be an issue with what he sells?
1973 MX250
1964 Honda 50cc C110
1960s Yamaha 65cc scooter
03 Dec 2021 23:47
- msavitt
Hackman101 - to be clear I was not referring to the person you mention, who I have bought from without issues. I used buzzard as a pejorative - like bottom-feeder, scavenger, etc.
The following user(s) Liked this Post: hackman101
04 Dec 2021 09:34
