Reed Valve Maintenance?
  • warmblood58
  • warmblood58's Avatar Topic Author
Reed Valve Maintenance? was created by warmblood58
Pulled the reed valve on my new to me '74 360DT, will check it carefully for cracks/gaps. OK to put in ultrasonic cleaner (I would imagine no heat best to avoid warping little doors?) Thanks!
04 Mar 2021 06:32 #1
Replied by turbodan on topic Reed Valve Maintenance?
All I would be concerned about is damage to the rubber coating on the block.  There's not much need for an ultrasonic cleaning really.  Unless it was left open and is full of dirt and leaves it should be pretty much spotless.
You can remove the reed petals and wipe them clean, make sure there is no grit or debris in the block.  That would be plenty thorough.
The following user(s) Liked this Post: MarkT, Yamadude, warmblood58
04 Mar 2021 14:31 #2
