Re:Shifting issues
- yamahoper
Replied by yamahoper on topic Shifting issues
Although that could not create an intermittent problem .
02 Jul 2020 05:11
#11
- Jimmyboy
- Topic Author
Replied by Jimmyboy on topic Shifting issues
So I pulled the plunger plug at the bottom to see if spring and rod were in place. Everything was in order. With rod out , I moved shift shaft up /down to see if maybe it might correct itself. But the problem remains. I fired it up and rode it , but it is in second and if you go up a half click Up it’s in some kind of neutral. Will not go into 3rd or 1st.
06 Jul 2020 07:22
#12
Replied by MarkT on topic Shifting issues
Bummer. Plunger and detent is the first and easy thing to check but it sounds like you're going to have to pull the clutch cover and clutch to check the sector gear timing.
06 Jul 2020 09:00
#13
- Jimmyboy
- Topic Author
I’ll take a look inside there and report back.
06 Jul 2020 11:56
#14
- Jimmyboy
- Topic Author
Ok I pulled the right side clutch cover off. This hadn’t been off since bike was made! Brutally hard to get off! Pulled clutch hub out of the way and from what I see about setting the teeth on shaft that it looks ok? I’m missing something here. Owner told me that it would only shift to first and go into neutral when I came to buy it, but I got on it and it worked perfectly. Then it acted up on me which is why I pulled cover, except it’s in 2nd gear and goes into a mystery neutral. Maybe the guy didn’t know it was in second when it acted up on him? And why did it start to work perfectly and then start to have problems again. I don’t know?
I moved the shifter and watched the shift drum click into gear, but when I tried to go up another gear it’s like the shift drum isn’t in correct place for the paw to click into it? Here’s some pics. Maybe you gurus can see something that I’m missing?
10 Jul 2020 18:09
#15
Replied by RT325 on topic Shifting issues
Ok, so the mystery remains. If you're changing up or down as you have it there you'll need to twiddle the main shaft a bit to feel the dogs in. May strike one or two gears that engage without help but only a luck thing if the dogs line up. that said--do you feel a definite click as the plunger holds it into gear on the drum cam the spring loaded plunger forces into.
10 Jul 2020 18:44
#16
If all else fails you might have to go right inside. Can't think what could go wrong in there in the way you're describing unless one dog has broken off a gear & got in the way of selectors moving sideways. Highly unlikely but i did have that on a brand new YZ400F "79 be unlikely on yours as its survived this long i suppose & only a recent issue. Maybe removed the gearchange shaft just to look in & around the claw arm & drum end for an obstruction--unlikely--but. I think it'd be too hard to turn the drum with a screwdriver when you have the shaft out & claw arm off as you'd be trying to turn the drum over the high point of the cam & plunger so don't be tricked by that. Could remove the plunger & spring then while twirling the main shaft back & forth it should be easy to screwdriver the drum through all 5 gears, although without the plunger you'll be only guessing each gear, But you should be able to go right through the range without an issue--unless there's an internal problem.
The following user(s) Liked this Post: Jimmyboy
10 Jul 2020 18:59
#17
- Jimmyboy
- Topic Author
So the feeling with it apart is the same as it was together . When I hit the shift lever it rotates the shift drum. The paw grabs it and moves it once . Reverse the shift and it moves it back where it started.
How does the screw adjuster work? Does it tighten the clearance with the paw to shift drum.?
10 Jul 2020 18:59
#18
The manual in the tech library has detailed troubleshooting and adjustment instructions.
10 Jul 2020 19:35
#19
No15 in the link is the stop bolt. In a DT1 or any of the earlier 250-360 models 'that' bolt is eccentric & adjustable for maximum movement. On your model it's Not adjustable. Unlikely --But-- if it had landed on the gearlever against a rock in an accident then that bolt might get bent. If you replaced it with one from a DT1-RT3 then you could alter it for more travel. That only half works because adjusting it one way takes movement from the other direction. The other screw No11 'is' eccentric to set the clearance to equal movement before it hooks the pin either way. Like-if you moved the gear lever up & down & had say 10mm upwards to touch the pin & 5mm moving it down to the pin then 'that' screw can be rotated to get equal free movement till pin is contact in both directions. Your stop bolt is highly unlikely to be bent. I'd pull the claw arm out & see if there's some foreign object restricting the movement. If you're testing it through the gears by gear lever without motor running--Or by turning the drum with all the moving bits out, you need to turn one shaft enough to feel the gears in. If the bike is assembled & you are sitting on the bike without motor running you would still need to rock it forward & back a fraction to get through all of the gears.
www.babbittsonline.com/oemparts/a/yam/50...09bc7849d6/shifter-2
After my confusing essay I'm thinking that its going to be an internal job, or will be if nothing obvious in where you are.
