77 dt400 running hellaciously...bad
  • the_trooper08
  • the_trooper08's Avatar Topic Author
Replied by the_trooper08 on topic Re:77 dt400 running hellaciously...bad
Reeds came in. And picked up an idiot proof mixing thingy.
Ordered oil injection blockoff plate.
13 May 2015 13:48 #61
Replied by Bigdog302 on topic Re:77 dt400 running hellaciously...bad
don't forget to read the instructions on the Boyesen reeds. there is directions on how to modify the reed cage to improve flow. they will add a bit of noticeable power and improve throttle response.
looks like your bike will do quite well! :OnFire
Dave
Jesus is Lord!
13 May 2015 13:53 #62
  • the_trooper08
I noticed the little instruction pamphlet, havent opened it up to take a peek but i sure will! Thanks!
All the repair parts should be here next wednesday from bikebandit.
So hopefully soon i can tear in and get it all done!
13 May 2015 14:10 #63
I am looking forward to it too! post pics or videos on it,we love those!
Dave
Jesus is Lord!
13 May 2015 15:09 #64
  • the_trooper08
Ok so its been over a year and not much has happened.
I have repaired my seat pan and recovered with an old army surplus duffle.
New feont fender and cleaned polished and painted a few bits.
Dug into the crank seals a bit tonight. Found after sitting for a year there is leakage from behind stator.
The 3 screws holding the stator on are slotted. To adjust timing. This is how its sitting now. Ill mark and reinstall in the same spot.
Sent from my SGH-I337M using Tapatalk
22 Jul 2016 22:47 #65
  • the_trooper08
Can someone tell me what page timing is on in the repair manual. I need good instructions lol.
Im an automotive mechanic that works on industrial oilfield aplications. This 2 stroke stuff is very different haha
23 Jul 2016 08:18 #66
which manual? is it a Clymer's, a factory shop manual or ???? I can find out on the factory manual. this site has the official shop Yamaha shop manual in the tech downloads section.
Dave
Jesus is Lord!
24 Jul 2016 06:50 #67
  • the_trooper08
The yamaha one off here. Thanks
24 Jul 2016 07:12 #68
page 14 under Timing (DT400D) in the first part of the book in maintenance also read the procedure for the DT250 on page 13 for steps 1 through 3.
basically you check and make sure the 3 lines on the flywheel, stator and cases all align at 2.9 mm BTDC.
rotate the crankshaft just almost 3 turns backwards.
Dave
Jesus is Lord!
Last edit: 24 Jul 2016 07:44 by Bigdog302.
24 Jul 2016 07:33 #69
  • the_trooper08
Thank you! Doing this tonight!
26 Jul 2016 19:06 #70
