My 76 YZ125 Restoration
- Grussell
My 76 YZ125 Restoration was created by Grussell
1975 DT250
1976 YZ125C (in progress)
1976 YZ125X (in progress)
2018 YZ250FX (my race bike)
2010 Triumph America (my cruiser)
- Grussell
Replied by Grussell on topic My 76 YZ125 Restoration
1975 DT250
Replied by MarkT on topic My 76 YZ125 Restoration
Wrong parts?
What do the ends of the pushrods look like? (especially the internal one) Yamaha used rounded ends on some models and deleted the ball.
Basket looks like it might be sticking up a little high but the pushrod is what looks the most "off" to me... it's sticking out pretty far.
- Grussell
MarkT wrote: Something looks wrong with the pushrods or actuator lever.
Wrong parts?
Both ends of the push rod are rounded.
1975 DT250
- Grussell
MarkT wrote: Here's info on the clutch... not likely "this" problem but could be important. has dimensions to ID the updated parts.
I will measure the components today and see how they compare. I used a parts diagram from RMATVMC that show a ball between the pushrods. Now that I think about it I couldnt find the ball when I reassemble so I thought it was missing. Maybe it didn't have one! I had 2 C engines disassembled and the other engine serial number is before this parts list applies. The engines had been disassembled for a few months. The serial number of this engine would definitely fall within the parts list you posted. I used the best parts from both engines so I will also inspect the other clutch components and see if I mexed them up.
Thanks Mark, I will let you know my findings
1975 DT250
In some of the parts lists I can find different pushrod options and "see notes"... but no notes. Look close at the YZ125c list and you'll see a pushrod listed as "0" above and then another different one below... then the ball is listed twice and even the push lever has a note. There definitely are some different pushrod options.
I've seen models of the 125/175 starting around 1976 come either with or without a ball. I will see if I can find any documentation.
- Grussell
Thanks again for sharing your in depth knowledge. Did you work in dealerships?
1975 DT250
- Grussell
1975 DT250
