shifting problem
13 Sep 2020 18:07
MotoDave0
Sportsman
Sportsman
More
shifting problem #1
Hi All,
A question for the Guru's..
Took bikes out for a test run the other day. The MX360 was running great, shifting thru the gears. Then I stopped and was going to practice a start. The bike would only go into 1st gear from neutral and back. any ideas on what this is?
Again the motorcycle was shifting fine through all gears and this just happened.
Thanks,
Dave
74 MX250 in a Profab frame
70 AT1 in a Trackmaster frame
72 RT2MX
72 DT2MX
74 MX360
Future rebuilds:
73 AT3
74 YZ80
71 JT1L 60
13 Sep 2020 21:55
RT325
Collector
Collector
More
shifting problem #2
No ideas yet that make sense. Plunger & spring still in place underneath on the left. Unusual thing to happen. What do you feel when pulling the lever up, as to go to second gear. Is it solid or does it move fully but feel like its not hooking the pins.
14 Sep 2020 19:41
MotoDave0
Sportsman
Sportsman
More
shifting problem #3
Basically the shifter feels like it would when shifting to first gear from neutral and back.
It even sounds good. (hear it click when shifting)
72 RT2MX
72 DT2MX
74 MX360
Future rebuilds:
73 AT3
74 YZ80
71 JT1L 60
14 Sep 2020 19:52 14 Sep 2020 20:05 by Rick C..
Rick C.
Collector
Collector
More
shifting problem #4
I would check this spring ( #10 ) and see if it is all there. Is it weak? RT325 is correct.
14 Sep 2020 20:21
MarkT
Site Supporter
Site Supporter
More
shifting problem #5
I'm curious if engine is running when trying to shift?
(Mostly because I don't think I could hear anything "click" with an MX360 running! :) )
14 Sep 2020 20:42
apex
Content Contributor
Content Contributor
More
shifting problem #6
Is the shifter bent inward, and contacting the case cover when shifting up?
Allrighty Then
14 Sep 2020 21:11 14 Sep 2020 21:12 by Rick C..
Rick C.
Collector
Collector
More
shifting problem #7
Kinda with you all on the , "We NEED Pictures " on this one and more info.
It could be as simple as what Evan said... bent shifter.
16 Sep 2020 12:58
MotoDave0
Sportsman
Sportsman
More
shifting problem #8
Rick, what exactly do you want pictures of?
The shifter is not bent, and looking at the clutch side of the shifting mechanism that looks fine.
I am going to double check that in a minute. then split the cases.
Mark, Of course the motor isn't running when I was shifting the gears.
The clicking noise was the stopper on the stopper plate.
You know I asked the question on this forum hoping someone may have had this happen.
And was hoping not to split the cases. But looks like I will split the cases and check it out.
72 RT2MX
72 DT2MX
74 MX360
Future rebuilds:
73 AT3
74 YZ80
71 JT1L 60
16 Sep 2020 13:39
MarkT
Site Supporter
Site Supporter
More
shifting problem #9
The reason I asked if the engine was running is because Yamaha transmissions don't like to shift unless shafts are spinning ... more difficult the higher the gear you try to shift into....
Rolling the bike while trying to shift gears should work though.
The following user(s) Liked this Post Hammer
28 Sep 2020 23:10
MotoDave0
Sportsman
Sportsman
More
shifting problem #10
Ok guys.
Problem fixed, here was the issue.
A while back I pulled the crank balancer out of the motor.
I left the bearings in the cases. So needless to say the inner race of the bearing part # 93390-00008-00 BEARING, CYLINDER. #90
worked itself out and bounced around the gears breaking up and jammed the cam shift.
So if you remove the Crank balancer remove every thing.
Lesson learned.
All good now, I am glad I have a 5 gallon bucket of gears.
72 RT2MX
72 DT2MX
74 MX360
Future rebuilds:
73 AT3
74 YZ80
71 JT1L 60
