Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
Yamaha YCS1 Electrical
Replied by RT325 on topic Yamaha YCS1 Electrical
If the cutout on the charging side didn't release when motor stops [below charging] it would then try to turn the charging side into a starter [but with no chance], the motor might move [i've tried it 50 years ago at work] but would have no chance of turning the motor,but something would have to give--like fry the smaller red wire tht recieves the charge back to the battery. [i'm guessing mostly from 50 years ago].
The following user(s) Liked this Post: rodss67
12 Mar 2023 19:05
#11
- akara1
Replied by akara1 on topic Yamaha YCS1 Electrical
Yes, from your photo that seems correct, its hard to see it on my computer.
#4 wire would be the starter solenoid wire, replace it with a thick 10GA wire from the screw terminal to the battery directly.
The regulator is mechanical, they can be revived, adjusted if not too far gone. Otherwise a used unit can be found on ebay, or the whole old electrical system can be chucked in the bin and someting like a powerdynamo ignition fitted, pros being no points and new parts, cons bein the cost and loss of electric starting.
The original factory service manual for the YCS1 has instructions on how to adjust and inspect the regulator
Here's a few excerpts from my CS5 and YDS5 manuals that use the similar regulator.
Usually all thats required is to clean the contact points with emery cloth and to inspect its operation.
The following user(s) Liked this Post: rodss67, nhsteve
14 Mar 2023 04:09
#12
- rodss67
Replied by rodss67 on topic Yamaha YCS1 Electrical
Thank you for your input. My daughter is here for a few days from California. When she leaves I will be back on it.
Any takers on what size fuse it will need?
14 Mar 2023 09:48
#13
Main [only] fuse i'd think would be 10 amp originaly.
14 Mar 2023 16:09
#14
Replied by MarkT on topic Yamaha YCS1 Electrical
10 amp fuse was the size on the magneto models.
Models with the 12v electric start (which also have to power the ignition coil(s) AND the headlight from the battery) used a 20 amp fuse.
The following user(s) Liked this Post: rodss67, RT325, nhsteve, Ht1kid, akara1
14 Mar 2023 19:27
#15
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
