Picture Attachment problem (09 Jul 2022)
Due to the extraordinary growth of the membership and resources, we are once again bumping up against hosting limits. I am working on a fix. In the meantime, the forum should function, but you won’t be able to attach images. Working as fast s we can to fix. Thanks for your patience. - Makotosun
Clutch Screws Yamaha YCS1
  • rodss67
  • rodss67's Avatar Topic Author
Clutch Screws Yamaha YCS1 was created by rodss67
I am having an abnormally hard time loosening the pressure plate screws. I cannot get any of them loose. Maybe being 65 is catching up with me. Any ideas or suggestions?  Thanks!
06 Aug 2022 18:33 #1
  • Ht1kid
  • Ht1kid's Avatar
Replied by Ht1kid on topic Clutch Screws Yamaha YCS1
Use a hand impact driver with a JIS bit works every time
06 Aug 2022 18:45 #2
  • rodss67
Replied by rodss67 on topic Clutch Screws Yamaha YCS1
Thank you so much!
06 Aug 2022 18:55 #3
Replied by RT325 on topic Clutch Screws Yamaha YCS1
Be very careful as will only be a 5mm thread not 6mm. Just me but i think a nice new sharp impact tip of the right size [& if JIS is the one, then that one] & a good T bar handle to turn it. Can see you've already slipped out but a new tip will still work just not one size undersize, gotta be 3 by the looks. I just use Koken short tips in my long 8mm T bar. A light tap to seat the tip in the screw then go for it, but push hard to stop it climbing out.
The following user(s) Liked this Post: MarkT, rodss67, PDXtyist
Last edit: 06 Aug 2022 19:47 by RT325.
06 Aug 2022 19:35 #4
  • rodss67
Good eye. Yes I did slip using a jis screwdriver. This is a first for me running across clutch screws that are so tight. I have bits but since I moved I cannot find them. Time to buy a new set. Thanks!
06 Aug 2022 19:46 #5
Yes they're not tight like spring tension tight as screw fully home butted up solid to the other half of the spring post. Just be carfull re-tightening if 5mm thread like i suspect & all my DT1 early model screws had been stretched by over zealous previous owners. Unless someone's loctite'd them in--they should turn out easily once cracked free.
The following user(s) Liked this Post: rodss67
06 Aug 2022 23:38 #6
Replied by automan on topic Clutch Screws Yamaha YCS1
Torch the screws to kill the loctite. 300-400f outta do it
cliff
07 Aug 2022 02:10 #7
  • rodss67
Do they come loctited from the factory?
07 Aug 2022 19:30 #8
Replied by MarkT on topic Clutch Screws Yamaha YCS1
Not that I've ever seen.
07 Aug 2022 20:45 #9
Nup, never seen that & not necessary anyway. Can imagine the grief that'd cause.
07 Aug 2022 21:04 #10
