Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
Gas to oil premix ratio
- Aintnothintoitbuttodoit27
Gas to oil premix ratio was created by Aintnothintoitbuttodoit27
I have a 1978 Yamaha dt250 that I use for ice racing someone on here once gave me a ratio and I’ve since lost the number and haven’t ridden in almost 2 years taking the bike out this weekend but I need to mix some fuel can anyone help?
06 Jan 2023 15:21
- automan
Replied by automan on topic Gas to oil premix ratio
can't go wrong with 20/1
40/1 is power mix in cold weather
cliff
cliff
The following user(s) Liked this Post: Aintnothintoitbuttodoit27, Crazy Horse 124
08 Jan 2023 10:17
- asco
Replied by asco on topic Gas to oil premix ratio
Jetting at high altitude plays a more important role than mixing ratios.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109 This email address is being protected from spambots. You need JavaScript enabled to view it. 1971 CT1-C ( BRANDY ) 1970 DT1-C
( MONICA ) 1972 AT2M ( ZIFFLE) 1970 CT1-B ( HULK ) 1971 DT1E
( GINA ) 1970 CT1-B ( CLIDE ) 1968 DT1 ( WILSON )
08 Jan 2023 13:01
Replied by Aintnothintoitbuttodoit27 on topic Gas to oil premix ratio
I meant to add that I thought 20:1 sounded right and you and everyone else has pretty much said the same thing can’t go wrong with it! Thank you for the response.
08 Jan 2023 13:28
- DaveHunter
Replied by DaveHunter on topic Gas to oil premix ratio
Mine are run with lots of oil, we have metal rubbing against metal in there under high temperatures /RPM speeds / friction…my grandfather used to say grease is cheeper than steel ….. What about power ….there was an article from a bike magazine & I think it is in the library here of a dynometer test using different oil ratios. The most horsepower was at a ratio of 16/1.
Yes that was from years ago so gas was different and oil too but until someone does actual tests I’ll run a mix non synthetic 20/1
The following user(s) Liked this Post: MarkT, Crazy Horse 124
08 Jan 2023 19:03
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
