Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
1972 CT2 slide needle setting
  • ay18176
  • ay18176's Avatar Topic Author
1972 CT2 slide needle setting was created by ay18176
What is the factory setting on slide needle? It was on top slot of the needle when I’ve had it off. Just wondering if that was correct.  I’ve been working on the slide sticking problem with advice from several of you. About to put it back on the bike and thought I would ask if this was correct setting on the needle Thanks for all of the help you all have given me.
27 Feb 2023 12:43 #1
Replied by RT325 on topic 1972 CT2 slide needle setting
I would normally say middle notch #3 but to be on the leanest as you found it it has me wondering if the needle jet is worn & someones been counteracting 'that', which only works to a point & not a cure--cure being replacement of needle & emulsion tube. Full of joy aren't i. I'm trying to negotiate the service manual section of the forum but page comes up off set & then goes 'fatal error'. Probably a 'me' issue. Link below doesn't help, just interesting.
yamahaoldbikes-list.blogspot.com/2021/01...5-specification.html
27 Feb 2023 13:17 #2
Ok, straight from the horses mouth [my original ct2 factory work sheet [from work--yes i worked once lol].
VM24SH Mikuni.
Carb id mark 314E1.
main jet 200.
air jet--it will be a drilling not changable.
jet needle-clip position 4L6-3 [3 being middle knotch].
needle jet 0-6.
cutaway [slide] 2.0
pilot jet 25.
air screw 2 turns out.
MarkT might say that's for Oceania & correct me if there's a difference. All good. I'm in NZ.
Last edit: 27 Feb 2023 14:33 by RT325.
27 Feb 2023 14:33 #3
Replied by Swoop56 on topic 1972 CT2 slide needle setting
There were two sets of carb specs for the CT2 . If the needle fitted to your carb is different
to the spec RT 325 has provided , you may have the update . I'd expect the ID would be 314 E2 .
27 Feb 2023 16:01 #4
Moderators: yamadminEnduronutMakotosunDEETVinnieDevin
