Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
1972 CT2 carburetor slide issue
- ay18176
Replied by ay18176 on topic 1972 CT2 carburetor slide issue
That makes sense. It may sit in my garage for two months between cranking and riding.
15 Feb 2023 03:21
#11
Replied by Gr8uncleal on topic 1972 CT2 carburetor slide issue
I've used Autosol metal polish with great success on mine - use on both the carb body and the slide (throttle valve) itself.
15 Feb 2023 04:55
#12
- asco
Replied by asco on topic 1972 CT2 carburetor slide issue
These 314 prefix carburetors are notorious for slide sticking. I cleaned one yesterday to put on eBay. Loosening the flange nuts and the top cap, helps. The bore fits tight. The slide will stick full throttle, a kill switch is a great idea and WD-40 is your friend. Many years ago I push started and bike ran away. Never push start that bike. Ask me how I know. I spent two hours yesterday cleaning two carburetor’s… They are very rare items when they operate correctly.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
- Dennis D
Replied by Dennis D on topic 1972 CT2 carburetor slide issue
Do you have any type of sealer in your tank?
15 Feb 2023 10:14
#14
- ay18176
Tank has been sealed before I purchased it
15 Feb 2023 18:02
#15
- ay18176
Thanks for that information. Are you aware of any good aftermarket replacements for this thing besides those cheap knock offs?
15 Feb 2023 18:09
#16
- asco
The short answer is no. OEM if you want your bike to run correctly.
a
a
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
15 Feb 2023 20:23
#17
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin
