Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
dial indicator and adaptor
- surfing
dial indicator and adaptor was created by surfing
Hello out there! another question! Where you can get the dial indicator and plug adaptor for timing the DT-1 ??? Thanks Mike
Old Desert racer District 37 and DRA in the 70's. Clubs OCMC and Sledriders. Living in Hawaii past 33 yrs. Have a restored 70 DT-1 enduro
01 Jul 2014 11:41
- pntrbl
Replied by pntrbl on topic dial indicator and adaptor
Harbor Freight Dial Indicators are fine. I use 'em.
I don't use a plug adapter tho. Pulling the head's easy and then I mount an indicator on this homemade rig.
The following user(s) Liked this Post: surfing
01 Jul 2014 17:18
- Winterwoods
Replied by Winterwoods on topic dial indicator and adaptor
NIce piece-of-art there, pntrbl.
I also pull the head on the DT/RT, and use the HF Digital on a like/same adapter.
On CT/TY(Straight Down), I use a homemade spark-plug adapter, built from an old plug:
c.winterwoods
c.winterwoods
- Makotosun
- Administrator
Replied by Makotosun on topic dial indicator and adaptor
Nice setup!
01 Jul 2014 18:13
- pntrbl
Oh yeah. There's an ATMX in my future. I'll be needing to make one of those ....
01 Jul 2014 22:12
- Winterwoods
Here is a straight-down shot.
I drilled and tapped-in a couple of 10-32 Hex-Head, Set Screws
after I cut off/cleaned out the insides of the spark plug.
A drop of Blue Loctite on each set screw, to keep them in place.
c.winterwoods
c.winterwoods
The following user(s) Liked this Post: surfing, pntrbl
- Le7316
Replied by Le7316 on topic dial indicator and adaptor
Winterwoods ,
Where did you get this Digital Dial Indicator ? What brand is this ?
- Lizeec
Replied by Lizeec on topic dial indicator and adaptor
Harbor Freight Tools, it is a discount tool supply in the U.S.
it is a Pittsburgh brand and cost around $30.00 reads in both sae and metric. Sometime they have coupons available for 20% off.
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
