Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
Tap extension 1/4" drive help ?
- Mauser
Tap extension 1/4" drive help ? was created by Mauser
- Pete-RT1
Replied by Pete-RT1 on topic Tap extension 1/4" drive help ?
www.cutwel.co.uk/catalogsearch/result/?q=tap+extension
1978 Yamaha DT175MX
- Top Jimmy
Replied by Top Jimmy on topic Tap extension 1/4" drive help ?
- Lizeec
Replied by Lizeec on topic Tap extension 1/4" drive help ?
I usually use a junk cheap brand 12 point socket either metric or standard and it usually grips well enough to cut threads, it kinda makes me go slower and pay careful attention to what I’m doing if it does slip.
www.amazon.com/Lisle-70500-Tap-Socket-Se...a-435960418711&psc=1
- Mauser
Replied by Mauser on topic Tap extension 1/4" drive help ?
- Mauser
- Mauser
- Pete-RT1
it wouldn't be hard to remove the bar then drill and tap the end, insert a stud then lock off with a nut.
Another alternative is to modify a flat bit extension.
www.screwfix.com/p/flat-wood-bit-extensi...EfD_BwE&gclsrc=aw.ds
1978 Yamaha DT175MX
Replied by MarkT on topic Tap extension 1/4" drive help ?
- msavitt
Replied by msavitt on topic Tap extension 1/4" drive help ?
