Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
Tear down & surprises on my '78 GT80
- worldmchn
Tear down & surprises on my '78 GT80 was created by worldmchn
I knew there was a few missing parts (kick start and oil tank being the 2 I knew about when I bought it), but I was surprised when I took off the left engine cover and the whole magneto was gone, backing plate and all. Actually looks like all the original wiring is also gone and what little is there is the remnants of this 'universal wiring kit' with a cdi off amazon (www.amazon.com/Harness-Complete-Electric...iring/dp/B08CDM8TGW/).
Next was the engine, took the carb off and cleaned/rebuilt it along with the fuel petcock, then took the cylinder jug off to take a look at the piston and rings since it didn't feel like it had a whole lot of compression and the reed valve looked fine, so checked it out and the piston and rings are broken (got most of the ring pieces out, looked like they stayed in the ring grooves for the most part, but I'll probably still take the crankcase apart just to make sure)
So now I'm looking at 1. Seeing what parts I can use from the 'universal kit' and piecing together a wiring harness from it. and 2. Getting a rebuild kit for the top end, but I need to figure out a magneto to put in there before I can start putting the wiring back together. I've done some looking around and it looks like a complete gt80 mag with the backing plate, points and rotor are pretty hard to come by, so I was wondering if anyone had an extra set they'd be willing to sell or knew of either another models mag setup or a good aftermarket one that'd work in it's place. Also any recommendations for a good top end kit or at least a piston and rings would be much appreciated.
Cheers!
-Nick
- msavitt
Replied by msavitt on topic Tear down & surprises on my '78 GT80
I have had success buying used virtually perfect wiring harnesses on eBay for reasonable prices vs trying to patch up a big mess…I think I paid $40 for one for my dt400. Same for magnetos but a bit more cash. Anyhow just some ideas. Good luck with bike!
- Schu
Replied by Schu on topic Tear down & surprises on my '78 GT80
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=195563002679&version=889&trackingid=&trackingpartnercode=9): failed to open stream: HTTP request failed!. Please enable debug mode for more information.
- Schu
CT1B, CT1C, JT1, JT2, DT360A, GT80B, DT100B, DT125B,
DT175B, DT175C, DT250B, DT400B, Z50, SCR950
- worldmchn
Replied by worldmchn on topic Tear down & surprises on my '78 GT80
- Schu
Also be aware that the little GT80 only runs comfortably at about 37 MPH. Its only a 4 speed and could really use a 5th gear. It's really too small to mingle in traffic.
- worldmchn
- worldmchn
After a few weeks of waiting, my points, rotor, and piston kit finally came in, so it was time to put the engine back together! Added a splash of the same hi-temp matte paint to the jug and head as well as clean + set the points to .012".
So shes mostly put back together, but now I still have a lingering problem. No spark. Or rather my ignition coil (I've tried 3 different ones) isn't sparking. When I've hooked my test-light up to the input wire coming from the mag, I get power, but nothing when on the output side.
- worldmchn
Replied by MarkT on topic Tear down & surprises on my '78 GT80
If you have an ohmmeter, what reading do you get between "input wire from mag" and and a good ground with:
1. Points open
2. Points closed
(no ignition coil connected during test)
My guess is that might be where the problem lies.
