Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
Keyster Carb Repair Kit
- Sleeman
Keyster Carb Repair Kit was created by Sleeman
Hey Guys,
I just wanted to write a little about the Keyster Carb rebuild kit.
I've got a 1978 DT175. It ran OK, but never right at the higher RPMs. I cleaned the carb a few times and it didn't seem to help. It would always kind of flubber at higher RPMS and also kind of pulse on and off when trying to maintain a speed and 5000K+ rpm.
Any way, i picked up the Keyster carb rebuild kit for about 30$ CAD shipped. I installed all the new jets /needle/ gaskets and the bike runs GREAT!.
Worth the money if you have any doubts about your carb
19 May 2016 13:42
- 1971DT250
Replied by 1971DT250 on topic Keyster Carb Repair Kit
I agree. I've used them in 7 rebuilds on DT/RT carbs. Nice quality and good performance.
19 May 2016 14:59
- jmagda
Replied by jmagda on topic Keyster Carb Repair Kit
So, the Keyster kits ARE good to use? Complete kits. I've read some entries in these forums that say DON'T use certain parts in the Keyster kits, but rather use only genuine Yamaha parts. Confused.
01 Mar 2020 12:25
- dgramo
Replied by dgramo on topic Keyster Carb Repair Kit
I ordered all factory yamaha parts. This way I was certain I was using quality correct parts.
01 Mar 2020 12:28
- 1971DT250
The ones I used were bought about 7 years ago. I must have gotten lucky or they were using good components back then.
01 Mar 2020 12:40
Replied by MarkT on topic Keyster Carb Repair Kit
Keyster uses their own "calibration"...
I've solved more running issues by going back to OEM jetting than I've seen Keyster jetting that works well.
One issue with Keyster is if you ever decided to ride at high altitude and needed to re-jet, you'd really have no idea where to start as their jets and needles are not calibrated the same as Mikuni...
01 Mar 2020 14:32
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Devin, James Hart
