Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
Yamaha sr125 1982 parts question
  • 7Chris6
  • 7Chris6's Avatar Topic Author
Yamaha sr125 1982 parts question was created by 7Chris6
Hey folks I have a 1982 yamaha sr125 and need some fork stanchions as they are pitted,I'm struggling to find a pair .... am I right in thinking the yamaha XT forks would fit as the Haynes manual covers both XT and SR. Are the parts interchangeable? It's drum brakes front and rear.Many thanks any help appreciated
29 Jul 2022 10:23 #1
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic Yamaha sr125 1982 parts question
I'm guessing a little as works in the yam shop but have never seen an SR125 only a 185 & 250. 185 had weird spoke setup in the wheels. Anyway, XT125 is leading axle & longer forks so forget that. If you wanted to fit the front forks complete you'd need the triples because of the offset between non leading and leading axle. Then you'd end up with forks hitting the tank on full lock as the triples sit back more inline straight across the stem, or close compared to straight axle triples stepping forward. What i'd do [& i'm rough at times] i'd spin them up in my lathe & emery them a little then new seals & fork boots & only you & i will know its rusted lol. Should see my DT1 which should leak but doesn't.
29 Jul 2022 17:27 #2
Replied by Gr8uncleal on topic Yamaha sr125 1982 parts question
What part of the world are you from? My reply is caveated that if you're not from the US, then it won't be as helpful.
Go to the CMSNL and/or Partzilla websites and follow your nose to your make, model, then parts listings. If you select on the part you're interested in, scroll down a little and you'll find a list of all other models that that part was fitted to.
This method is not so good for European models, as neither website has a comprehensive list of parts manuals for those bikes.
Franks Forks in the US might produce repros.
30 Jul 2022 00:00 #3
Replied by DT-Steve985 on topic Yamaha sr125 1982 parts question
Not really anymore help but just wanted to say welcome along, I’m sure you will get all the help you need as there are a lot of very helpful and knowledgeable folks on here.
30 Jul 2022 05:21 #4
Moderators: EnduronutMakotosunDEET
