Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
Getting 74 DT/MX race ready - wiring simplification
- Jbeebe
Getting 74 DT/MX race ready - wiring simplification was created by Jbeebe
Hey everyone,
I have what I believe to be a 74 DT250. I'd like to get it running and get it race ready, in part, by stripping down electronics. It has most of the electronics still on it including the battery, headlight, taillight assembly, flasher relay, and rectifier. Here's a picture of the magneto/points/coils:
Can I just take the black wire from the magneto and run it right to the ignition coil, interrupting it with a kill switch on the handlebar? I know this bike came with a battery but I don't see how it would be necessary without using any other electronics.
Here's the coil with the black/white band wire that I would hook into:
Thanks guys!
Thanks guys!
Replied by RT325 on topic Getting 74 DT/MX race ready - wiring simplification
Short answer--yep, black straight to the coil, & as you say, with a kill switch.
11 Dec 2021 18:37
- Jbeebe
Replied by Jbeebe on topic Getting 74 DT/MX race ready - wiring simplification
I appreciate the short answer, I'm not to good at those! haha.
12 Dec 2021 01:10
Replied by MarkT on topic Getting 74 DT/MX race ready - wiring simplification
Tape off those other wires so they don't touch anything.
Kill switch wire simply tees into black and shorts the black to ground. Not sure it that's what you meant by "interrupt". (I've seen someone try to insert a switch to disconnect the black, doesn't work too well.)
In the diagram above you can see how "main switch" tees into wire from stator to ignition coil... (highlighted in red)
12 Dec 2021 05:10
- Jbeebe
Thanks for the reply! Yea I can see how using the word "interrupt" usually means just adding a switch in the line. Thanks for clarifying that the switch needs to connect it to ground.
14 Dec 2021 04:34
Moderators: Enduronut, Makotosun, DEET
