Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
coil replacement
  • peterd
  • peterd's Avatar Topic Author
coil replacement was created by peterd
Good Morning,   Have a 1971 RT1B and the coil wire is to short,  Its rubbing on the bottom of the tank and its only a matter of time before it rubs thru.  Can I replace the wire only or does the entire coil need to be replaced?  I have great spark and I also see the coil is not available.  I tried to simply unscrew the wire from the coil and it will not budge.  Any suggested replacements for the coil?
When all you have is a hammer....everything looks like a nail
Peter
04 Jul 2021 03:09 #1
Replied by MarkT on topic coil replacement
I think DEET has managed to replace those wires...  on the ones that don't just unscrew it sounds like it's a project.  I want to say DEET posted about the process here someplace.
NGK makes a spark plug wire "splice".  I keep one in my spares for an emergency. I've had it close to 10 years and haven't needed it yet.  amazon.com/NGK-J-1-Racing-Cable-Splicer/dp/B0018JXIXI/
You may need a length of good copper core wire as well.
Last edit: 04 Jul 2021 06:02 by MarkT.
04 Jul 2021 06:01 #2
Replied by RT325 on topic coil replacement
I have a long time ago cut the surface off where the wire comes out of & soldered a new wire in then Araldite two tube mix glued it over the top. Worked for me. It was a grey colored coil.
04 Jul 2021 16:13 #3
Replied by shyted on topic coil replacement
Not a solution if you want standard original fitment but i fitted a new coil but had to make a new bracket to mount it as it was a more up to date design. New screw in lead and cap .
04 Jul 2021 23:46 #4
Moderators: EnduronutMakotosunDEET
