Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
Clutch adjustment
- knobrega
Clutch adjustment was created by knobrega
I am completely baffled. I can not for the life of me get the clutch cable adjusted. It is almost like the cable is too long. I have done the adjustment on the clutch itself and on the cable. I have the cable all the way adjusted in and it still does not engage. I feel like it needs an additional adjuster up on the perch but it did not come with one.... help!
29 Jul 2022 10:22
- Mini Enduro Man
- Supporting Moderator
Replied by Mini Enduro Man on topic Clutch adjustment
I wish I could attached a picture to help explain..... but did you put in the small ball bearing along with the push rod shaft?
the push rod should be extending out of the case about 20.5mm
29 Jul 2022 10:49
- Mini Enduro Man
Another common issue is that the worm drive gear on the clutch accuator inside the stator cover is cracked and slipping every time you pull theclutch lever in.... That has happened to me many times!!
29 Jul 2022 13:13
- knobrega
Replied by knobrega on topic Clutch adjustment
both are in place. I just pulled it apart and looked.
29 Jul 2022 15:14
- knobrega
That appears to be intake and working. Any other ideas?
29 Jul 2022 15:24
Replied by RT325 on topic Clutch adjustment
Ball bearing still in the actuator?, takes up a bit of play plus its necessary as the rod likely tries to revolve. So long as the center adjustment in the actuator is set to minimum which should in theory have the arm right down & taking up cable free play--there nothing else i can think of except cable stretch which is unlikely. I'm guessing its a JT1 & only have a lower cable adjuster thinking back 50 years. I think the worm is plastic/nylon & could split like on a DT1.
29 Jul 2022 17:13
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Mini Enduro Man, Devin, James Hart
