Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
Black wire for flasher?
- mryan
Black wire for flasher? was created by mryan
The flasher's have never worked on this bike for a long time. They do light up along with the indicator on the speedo, just never flash. So I'm guessing the flasher is bad. But now that I see this black wire broken and not connected to anything, could this be the problem? One end is attached to the frame and were does the other end connect to? any ideas? See photo's.
25 Jun 2022 10:16
Replied by MarkT on topic Black wire for flasher?
The original flasher has 3 wires plugged into it and one is ground. So look where the wires hook to flasher. Can't see wire connection to flasher in your pictures.
If you change flasher BUY A 2 WIRE. Modern flashers don't have ground wires anymore and if you buy a 3 wire you'll have a direct short.
Of course if you buy a NOS Yamaha flasher for big $$$ then just get the original.
25 Jun 2022 12:46
- mryan
Replied by mryan on topic Black wire for flasher?
It did have a 3 wire original, black wire plug into ground. I replaced the 3 wire flasher with a 2 wire and grounded the outside of the flasher to that black wire and it works great now.
26 Jun 2022 13:13
Great job!
(The new flashers don't normally need to be grounded but it probably can't hurt.)
27 Jun 2022 06:10
Moderators: yamadmin, Enduronut, Makotosun, DEET, Vinnie, Mini Enduro Man, Devin, James Hart
