Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
Hi guys!
Replied by RT325 on topic Hi guys!
ridermagazine.com/2018/01/29/the-seminal-motorcycle/
Replied by Ht1kid on topic Hi guys!
- Crazy Horse 124
Replied by Crazy Horse 124 on topic Hi guys!
"Turn signals were not and are not required for street use in the USA if bike was manufactured before 1-1-1973."
So you are saying that even though turn signals were OEM from 1971 on they are not required on my 71?
- AirborneSilva
Replied by AirborneSilva on topic Hi guys!
1972 DT2 250
- AirborneSilva
1972 DT2 250
- SuperKev
Replied by SuperKev on topic Hi guys!
I’ve had the bike dated via the vin/engine numbers as looking at registering it over here in the uk.
Replied by MarkT on topic Hi guys!
Short answer: Check your state law.
Federal law did not require turn signals on motorcycles until 1973. Most states follow Federal law, but there could be exceptions.
The ORIGINAL Nevada law on motorcycle turn signals hit the books in 1971 and said any motorcycle manufactured after 1-1-72 had to have turn signals. That law was repealed and replaced to be consistent with Federal law that said 1-1-73.
Every state I've checked has their current motorcycle turn signal law consistent with Federal law... that doesn't mean all do... and it's likely Yamaha started putting turn signals on bikes in the 1971 model year because some states started requiring them?
The "motorcycle sold in USA must be manufactured so headlight must always be on with engine running" law was something the Feds came up with in about 1978... but every state I've checked still follows the "common sense" headlight on rules which are usually headlight on half hour before sunset and half hour after sunrise... or if visibility conditions warrant the use of a headlight. So you probably don't need to ride around on the street during the day with your headlight on if you want to be a rebel and have an older bike that has a headlight on-off switch. Again, check state law.
One thing about all state light laws is generally "if you have them, they need to work". So you can't have turn signals installed on a 1968 bike and try to say it's ok if they don't work because you don't need to have them... or ride around with a burned out headlight because it's daytime... if you have them, they have to work.
- shyted
Replied by shyted on topic Hi guys!
It also ended up in Canada . I'm sure i read some place on another post that Yamaha offered them as an optional extra on all their bikes of that era.
- SuperKev
Kev
