Picture Attachment problem (09 Jul 2022)
Due to the extraordinary growth of the membership and resources, we are once again bumping up against hosting limits. I am working on a fix. In the meantime, the forum should function, but you won’t be able to attach images. Working as fast s we can to fix. Thanks for your patience. - Makotosun
Hi guys!
- SuperKev
Hi guys! was created by SuperKev
I’m still after a few parts like switchgear
Replied by Gr8uncleal on topic Hi guys!
The forum is US based, with most members located there. However, there a quite a few UK members, with others from mainland Europe and Australia/New Zealand.
If you haven't done so already, check out the CMSNL and Partzilla websites. Click on a part, scroll down and they will show all models which used that part.
- AirborneSilva
Replied by AirborneSilva on topic Hi guys!
1972 DT2 250
If your stay is from an AT, then I'm not sure it will fit the HT (CMSNL shows only the LT as sharing the same part). HOWEVER, if it is what Kev needs, then it might save a few quid on postage if you pop it in the package that you'll (hopefully!) be sending to me, and then I can forward to Kev.
Replied by RT325 on topic Hi guys!
- AirborneSilva
1972 DT2 250
- AirborneSilva
1972 DT2 250
- DT-Steve985
Replied by DT-Steve985 on topic Hi guys!
I needed the wiring loom and switch gear for mine and through Alan and Tony it was sourced and distributed from the US.
- AirborneSilva
1972 DT2 250
That might be quite a rare part - early style, but with indicator switch.
That looks like a 1969 model rear light - have you checked the frame and engine numbers against those in the VIN tables (see top toolbar) to confirm?
Tony, I was wondering if maybe the difference between the AT and HT/LT stays is that AT is chrome and the HT/LTs are painted silver?
