Picture Attachment problem (09 Jul 2022)
Due to the extraordinary growth of the membership and resources, we are once again bumping up against hosting limits. I am working on a fix. In the meantime, the forum should function, but you won’t be able to attach images. Working as fast s we can to fix. Thanks for your patience. - Makotosun
Hi, 1972 Yamaha ct1 175
- Dugadie9
Hi, 1972 Yamaha ct1 175 was created by Dugadie9
Whats the piston rings original part number please?
Replied by Ht1kid on topic Hi, 1972 Yamaha ct1 175
Do you need standard, first oversize rings etc? Tell us some more details also there probably is a parts list in the tech library also a 72 is a CT2 check your vin in the library
- Dugadie9
Replied by Dugadie9 on topic Hi, 1972 Yamaha ct1 175
it’s a standard size.
Replied by Gr8uncleal on topic Hi, 1972 Yamaha ct1 175
First thing is to pin down exactly which model you have - check your engine and frame numbers against the VIN tables in the Tech Library (see top toolbar). The numbers would originally have been the same, but previous owners might have mixed and matched them over the years.
A 1972 model will be a CT2, although the frame number will commence CT1.
As well as the parts lists (and manuals!) that Ht1kid mentioned, CMSNL and Partzilla are great sources of parts and parts information.
- Dugadie9
- Dugadie9
The 1972 and 1973 CT2 and CT3 had reed valves, the earlier CT1 did not. The cylinders are therefore obviously different as, I believe, are the pistons and rings. However, wait for others to confirm.
- Dugadie9
- Rick C.
Replied by Rick C. on topic Hi, 1972 Yamaha ct1 175
- mike8162
Replied by mike8162 on topic Hi, 1972 Yamaha ct1 175
Cheers
