Carb Rebuild
28 Sep 2020 10:26
Pap
Newbie
Newbie
More
Carb Rebuild #1
I have a mikuni vm24sh carb i would like to rebuild Can someone tell me the jets I should replace and a good place to get them Thanks
28 Sep 2020 10:45
Mauser
Collector
Collector
More
Carb Rebuild #2
I look here....find your bikes year then your bike model and away you go....
vickerymotorsports.com/Parts-Look-Up/yamaha/motorcycles
Yamaha RT2 360 ~ Honda XR650R ~ Yamaha DT175MX ~ Kawasaki KH400
28 Sep 2020 12:20
Pap
Newbie
Newbie
More
Carb Rebuild #3
Thanks Mauser
28 Sep 2020 14:49 28 Sep 2020 14:51 by RT325.
RT325
Collector
Collector
More
Carb Rebuild #4
Ok, i wrote an essay below thinking your carb is a DT1 old style. Ignore most of my dribble if its not that type sorry.
Jets don't wear out. Possible but unlikely that the slide needle & emulsion tube might wear where the needle slides in it. Slide itself is unlikely to be worn but you'd visibly see it if it was. Just pull all the jets & make sure they're clean. That includes removing the needle jet/emulsion tube. Study the slide needle for visible wear. Clean, prod the choke fixed jet in the bowl cavity. & most important is the very small Oring on the jet setter where it seals into the bowl. If that leaks the carburation goes all to hell in a hand cart. Link below--if it works--shows wear in the needle jet, very visible in this case. Cheers.
www.factorypro.com/tech/needle_jet_wear.html
29 Sep 2020 05:16
Pap
Newbie
Newbie
More
Carb Rebuild #5
Thanks RT Here is my problem I have a ct3 175 I put an after market carb on and it works ok but seems to dog on the high gears so I cleaned up the old carb (mikuni) it starts quick but smokes and bogs down like the choke is on I dont Know a lot about these carbs but Im trying to learn
29 Sep 2020 10:50
Gr8uncleal
Site Supporter
Site Supporter
More
Carb Rebuild #6
Have you replaced the 'O' ring that sits on the Main Nozzle yet? Not guaranteed to solve your problems, but it won't do any harm and is cheap.
The following user(s) Liked this Post MarkT
29 Sep 2020 11:20
MarkT
Site Supporter
Site Supporter
More
Carb Rebuild #7
Yes, your problem with the original carb sounds like the o-ring that seals the jet setter to the main jet well in the bottom of the carb.
29 Sep 2020 11:28
Pap
Newbie
Newbie
More
Carb Rebuild #8
No I have not replaced it but I will Thanks guys
