Hi From New owner of 76 DT400 ready for restoration
30 Jan 2020 21:08
MarkT
Site Supporter
Site Supporter
More
Hi From New owner of 76 DT400 ready for restoration #21
Mentioned a bunch of times if you do a search... briefly third wire is a ground on OEM yamaha. Third wire is for "pilot light" on most three wire flashers.. If you connect all three wires you'll have a direct short.
Can probably use the three wire if you don't connect the pilot light or you could rewire the flashers and run a wire from pilot to bulb in gauges and disconnect both wires to existing indicator in gauges.
31 Jan 2020 09:10
Wessi
Novice
Novice
More
Hi From New owner of 76 DT400 ready for restoration #22
Hi Jason, just take the springs from the shock absorbers to a chrome shop. They remove old chrome/Nickel/copper layers, polish and rechrome. If rust Mark's are not to deep, polish before chroming is ok. If too deep, sand blasting ( rounded corn) before rechrome, what's more like the stock spring's. I payed 15 Euro each spring (approx 20 Dollars) in Germany for de- and rechroming, and don't have to think about adhering or what it looks like anymore. Just the best solution and not expensive.
31 Jan 2020 11:46 31 Jan 2020 11:59 by Asbeablah. Reason: found the answer to my previous question
Asbeablah
Mini Enduro
Mini Enduro
More
Hi From New owner of 76 DT400 ready for restoration #23
Hi Guys,
Thanks MarkT for all the help. Wessi tx.
If I follow the wiring diagram available on this site, and stay with regular lights (only 12V upgrade) everything should work?
tx
Jason
02 Feb 2020 20:51
Asbeablah
Mini Enduro
Mini Enduro
More
Hi From New owner of 76 DT400 ready for restoration #24
Hi Guys/Mark,
Thanks for the feedback, 2pin flasher relay worked very easily. All wiring for turn signals are complete. Conversion to 12V bulb is complete. Next is hooking up the instrument lights. I got the 12v Bulbs, and will follow the wiring diagram to see if they work. if there is anything i should deviate from the wiring diagram please let me know?
Tx
Jason
03 Feb 2020 09:56
Grussell
Sportsman
Sportsman
More
Hi From New owner of 76 DT400 ready for restoration #25
I have been using rocky mountain atv/mc for parts for my 78 dt400. I found this part number 102-25137-00-00. Item 37 on the attached diagram. Is this what your looking for? [attachment=32668]
1978 DT400 (in progress)
1975 DT250
2018 YZ250FX (my race bike)
2010 Triumph America (my cruiser)
16 Feb 2020 19:09
Asbeablah
Mini Enduro
Mini Enduro
More
Hi From New owner of 76 DT400 ready for restoration #26
Hi Guys,
Thanks to everyones great help here, I have completed the cosmetic restoration on the DT400. It started right up with just a two kicks (with Choke), and idle is very stable. However upon taking it for short spin down the cul de sac and the engine doesn't respond to throttle above 1/4 throttle. I only tried first gear.
Love to hear back as to where to start. Planning to take out the carb.
Previous owner told me compression is about 115PSI and engine sound is very good. its been upgraded to 12V Ignition system.
Thank so much for great support here.
Jason
This message has attachments files.
16 Feb 2020 19:23
Bobv07662
Site Supporter
Site Supporter
More
Hi From New owner of 76 DT400 ready for restoration #27
Sounds like the main jet is plugged.
