Picture Attachments Fixed? (18 Feb 2023)
Hopefully, the pictures uploads are fixed for the time being. Let me know if you continue to have issues. I am looking into a more permanent solution. Thanks for your patience. - Makotosun
IT175F Rear shock bump stop
Replied by RT325 on topic IT175F Rear shock bump stop
You're safe to screw the top off if you can hold the shaft from turning. No nitrogen or oil should escape. There is a danger if the gas has got past the gas piston Oring but won't affect what you're trying to do. You'd know if that's happened because it'd be all gas springy with little damping. If you then wanted to completely dismantle it the shock body has to be drilled to let the gas out then drilled bigger to fit a special valve. That's the short version not including other things involved for a total dismantle.
02 Sep 2022 00:46 #11
  • Flint
  • Flint's Avatar Topic Author
Replied by Flint on topic IT175F Rear shock bump stop
Ok thanks.
12 Sep 2022 17:03 #12
Had to re-read what i wrote to be sure we we're just talking the end off the shaft to replace bump stop. All good.
The following user(s) Liked this Post: Flint
12 Sep 2022 18:57 #13
