‘78 DT400E brake shoe identification
  • msavitt
  • msavitt's Avatar Topic Author
Hello - hoping than an edurologist can help me ID replacement shoes based on the markings below. I ordered two pairs and neither fit. And this bike has a few surprises so I am wondering if something got switched around…I don’t think so but then again is it likely two ebay sellers got it wrong?
really appreciate the help
martin
martin
21 Sep 2021 21:13 #1
  • msavitt
Replied by msavitt on topic ‘78 DT400E brake shoe identification
Thanks Rt325
i started with parzilla and ended up getting incorrect shoes twice and was hoping to turn markings on shoe photos into part numbers.
I think the front shoes might be oddballs for 77 and 78, but seller had a wider range of years. I think the back set is same as rear in my dt360a and dt1e so I think I will buy these from partzilla. Front not available from partzilla which takes me back to eBay and all this Chinese no name stuff.
21 Sep 2021 23:39 #3
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic ‘78 DT400E brake shoe identification
Maybe have a go at starting your search on the CMSNL website.
The set in your first photo actually have a part number stamped on them (183-........) and on the other side is stamped 437, so I guess they fit a 1974 DT100 + loads of others.
The second set, as you've already sussed, is the set currently used on the DT3 etc etc.
I recall reading somewhere that the DT250/400 switched to a conical front hub, possibly within a production year, so this is probably the source of a lot of the confusion out there (that, and Yamaha's myriad of part number supersessions!).
22 Sep 2021 00:20 #4
Replied by MarkT on topic ‘78 DT400E brake shoe identification
Try checking with an actual Yamaha dealer.  They have a crossover chart of some kind that identifies brake shoes and is not available on the on-line parts lists.  Front and rear Partzilla part number on the 79 DT175 are the 437-W2536 -00 and NLA
So I had the same problem with my 79 DT175 and the local dealer looked it up in a paper book they had under the counter. If the 437 shoes are what you need the current Yamaha part number should be in the pic below...  130mm OD.
The following user(s) Liked this Post: abrace
22 Sep 2021 03:27 #5
  • msavitt
thanks all
22 Sep 2021 07:21 #6
These might be the front ones...  supposed to be 160mm x 30mm
1HX-W253E-00-00
www.partzilla.com/product/yamaha/1HX-W253E-00-00
Last edit: 22 Sep 2021 13:35 by MarkT.
22 Sep 2021 13:34 #7
  • msavitt
thanks Mark
I will try this if my 3rd swing is a miss!
22 Sep 2021 14:11 #8
  • msavitt
Hi Mark - mystery continues.
my front shoes measure 130mm across the diameter installed so I am thinking that 3kg-w253e-00 might be the ticket. Do you know what the width of these shoes are?  Thank you
23 Sep 2021 23:22 #9
  • Gr8uncleal
Did you check out CMSNL?
They show part number 431-W2536-00, superseding to 4GR-W2536-00, although this may well not be the complete supersession history.
They also show Ferodo part number FSB767 as an alternative.
24 Sep 2021 00:22 #10
