1978 DT175 - help with rough running
Description of problem: Bike can be started alright, takes a couple kicks, and idles alright (haven't fully dialed in idle since I'm having bigger issues). It runs, but very poorly: power is a little jerky, and sluggish at low RPM, but feels like full power with a good throttle pull. Coming to a stop, it stalls every time, then takes a few kicks to start again. Bike runs worse off choke, but also is fairly smoky (though nothing horrendous). Sounds terrible to me, but I'm not 100% sure how much is standard 2-stroke noises vs. my specific issues. I have a short video of a 50 yard ride herehere if it's helpful.
What I've done so far: cleaned the carb (twice), taking care to clean all the jets. I'm fairly confident I did this right (not my first gummed up carb). Float isn't quite right (slight fuel drip out of float bowl overfloat), but I don't think it's related.
Cleaned the tank and serviced the petcock, so fuel delivery shouldn't be an issue. Fresh gas too.
Checked that the autoluber was working.
Replaced the spark plug (gapped to spec), and checked spark.
Cursory compression test (thumb on spark plug hole) - haven't properly tested compression though.
Things I'm wondering about:
Timing issue or intermittent CDI failure? lack of primary compression? Something with the reed valve? Leaky head gasket? Fuel mixture problem?
I'm just not very familiar with 2-strokes, any guidance would be very much appreciated! Can take a video and post it if that would help
Have you checked the pipe for any sort of blockage? Anything from excess carbon to a real live mouse nest? Don't laugh; it's happened before.
Idle and air screw were set to spec (1978 was the last year with an adjustable air mix screw, lucky me). Haven't checked the pipe actually, though I've had nothing flying out the exhaust at all, rodent or otherwise, so I think it's clear, but definitely worth a check :P
Did the video work for you? Would love some opinions on whether that bike sounds wrong or whether that's just 2-strokes doing 2-stroke things.
(For video you need to upload to YouTube and link here... or another video hosting site but YouTube link will imbed video here automatically.)
MarkT wrote: Maybe just me, but I don't see a video?
He posted with a Go Pro.com link, those won't work to my knowledge anyway.
Dave
Jesus is Lord!
There is a spec for the float level / needle/ seat, setting the level of fuel in the bowl. A small piece of rust or debris could be holding the needle/seat open and overflowing fuel.
It actually runs best when running up through the gears - Video only goes to 3rd, but I can go higher/faster without it misbehaving much.
I'll redo the float and needle first thing then, and see how much that helps. Previous bikes have had issues with float levels, and the the way they were affected seemed different - I've had fuel starvation before (on my 4-stroke street bikes). I also would have thought that if the issue is overfilling from the float setting, it would behave better after running it around a couple minutes, not worse. I'm clearly misunderstanding something though, hopefully the video is helpful.
Thank you all for the quick responses! Feels great to get some input after struggling by myself for a while.
