DT125E Won't Start
22 Mar 2020 09:03
C Team
Sportsman
Sportsman
More
DT125E Won't Start #1
I picked up a 1978 DT125E from original owner that has been barn sitting for years. I cleaned the fuel shut off, replaced fuel line and inline filter, removed carb and check float to make sure not stuck. Everything looked surprising fine with the carb. No debris or gunk in the bowl. Float moved freely up and down. I removed the reed valve assembly and the reeds check out fine according to my manual. Installed new sparkplug and getting spark but the bike won't even try to fire. I sure hate to pull the carb back off because installing it was a bear. After quite a few kicks, I removed the sparkplug and it was a little wet with fuel but still would make spark.
I check compression by holding my finger over the sparkplug hole and seems to be ok even thought I can't confirm since I don't have a compression gauge.
I'm open for suggestions from the knowledgeable people on this forum!
Thanks! Craig
22 Mar 2020 09:32
LongStride
Sportsman
Sportsman
More
DT125E Won't Start #2
Check if something stopping up exhaust
22 Mar 2020 09:34
C Team
Sportsman
Sportsman
More
DT125E Won't Start #3
I removed the spark arrestor and looked down the pipe. No obvious signs of blockage.
22 Mar 2020 10:03
MarkT
Site Supporter
Site Supporter
More
DT125E Won't Start #4
Carb might have looked clean but pilot jet and starter jet in float bowl well could be restricted. The later models don't start well without the starter circuit.
Also make sure plug is wet with fuel and not oil. Bikes that sit tend to fill up crankcase with oil that slowly bleeds past the check valve.
I'd pull the pipe off and see if bend full of oil and if it's spitting oil out exhaust when kicking over.
22 Mar 2020 10:37
C Team
Sportsman
Sportsman
More
DT125E Won't Start #5
No oil on plug but did notice white smoke coming out of the exhaust as I was kicking. Should you be able to turn over by hand using the kicker pretty easy? I have the bike on a lift and I can hand crank very easily using the kick starter. I'm wondering if compression is an issue?
22 Mar 2020 10:40
Super90
Sportsman
Sportsman
More
DT125E Won't Start #6
Check your air filter. Mine had an old foam filter that was disintegrating...small pieces of it were getting sucked into the carb in my case. you can always remove the filter and try to start it in the garage just to see if it will start. Good luck!
22 Mar 2020 10:51
C Team
Sportsman
Sportsman
More
DT125E Won't Start #7
Super90 wrote: Check your air filter. Mine had an old foam filter that was disintegrating...small pieces of it were getting sucked into the carb in my case. you can always remove the filter and try to start it in the garage just to see if it will start. Good luck!
I put a brand new filter in before trying to even start this bike. I check that the first day I brought the bike home and it was all disintegrated.
The following user(s) Liked this Post Super90
22 Mar 2020 14:37
Steve F
Site Supporter
Site Supporter
More
DT125E Won't Start #8
If you'd like to have this manual, send me a pm.
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
"And there ya have it"
The following user(s) Liked this Post 2fishkev, KennyV, Schu, Super90
23 Mar 2020 03:39
C Team
Sportsman
Sportsman
More
DT125E Won't Start #9
I'm trying to figure out how to PM you.
23 Mar 2020 05:38 23 Mar 2020 05:39 by Steve F.
Steve F
Site Supporter
Site Supporter
More
DT125E Won't Start #10
I sent you a message this am. All you need to do is reply. Look for the red dot above your Messages box on your member page & click.
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
