Rear wheel spacer 69 L5T
25 Nov 2019 21:21
rodss67
Sportsman
Sportsman
More
Rear wheel spacer 69 L5T #11
Locktite worked well. Thank you sir.
25 Nov 2019 23:25
RT325
Collector
Collector
More
Rear wheel spacer 69 L5T #12
rodss67 wrote: Locktite worked well. Thank you sir.
That's good.
08 Dec 2019 20:12
rodss67
Sportsman
Sportsman
More
Rear wheel spacer 69 L5T #13
I installed the rear wheel assembly on the frame and when i spin the wheel the sprocket nuts hit on the swing arm unless the it is slid towards the back of the adjustment slots in the swing arm. When i tore it down there was 2 washers between the distant collar and swing arm that is not shown on the parts schematic. Is it ok to put them back or is there another problem. Nothing appears to be bent.
09 Dec 2019 15:51
RT325
Collector
Collector
More
Rear wheel spacer 69 L5T #14
No sure why that would be. is it assembled as per the partzilla drawing with circlip & all. Although if the circlip was missing then it could only move away further--all unlikey events. Can you turn the sprocket bolts around so the nuts are on the inside proving the bolt head is thinner than the nut with. Not the wrong spacer in there.
09 Dec 2019 18:05
MarkT
Site Supporter
Site Supporter
More
Rear wheel spacer 69 L5T #15
It's possible the original spacer was lost at some point? Maybe a different spacer from a similar model was found but was a little shorter hence the washers.
I'd check ebay by the part number and by the bike model and then message the sellers for a length measurement to compare to what you have.
09 Dec 2019 18:58
rodss67
Sportsman
Sportsman
More
Rear wheel spacer 69 L5T #16
I will try flipping the bolts around but am sure i would get the clearance as the bolt heads are thin. Thanks!
09 Dec 2019 19:09
rodss67
Sportsman
Sportsman
More
Rear wheel spacer 69 L5T #17
I wondered about that spacer. This bike had a bit of cobbled together hardware on it so i would not be surprised if it is incorrect. I emailed a seller and hope i hear something tomorrow. For a bike that was showing barely over 2k on the clock, it was a hard ride eventhough it started easy and ran like a watch.
Thanks to both of you for helping me thru this. I would only want to use the washers as a last resort.
Rodney
09 Dec 2019 21:51
Swoop56
Site Supporter
Site Supporter
More
Rear wheel spacer 69 L5T #18
It might be worth running a string line between front and rear sprockets ,
to check they are in line . If not check spacers for correct length as others have suggested .
10 Dec 2019 09:39
rodss67
Sportsman
Sportsman
More
Rear wheel spacer 69 L5T #19
I have not yet installed the engine back into the frame but when i do i will check the alignment.
Thanks!
13 Dec 2019 10:15
rodss67
Sportsman
Sportsman
More
Rear wheel spacer 69 L5T #20
Finally got an answer and he measured the new at 13/16" and the one i have is 1/2". I ordered it and i will see when it arrives. I will let you know.
Again thanks for the help.
Rodney
The following user(s) Liked this Post MarkT
