Piston ring interchanging
20 Sep 2020 14:16
endurosite
Newbie
Newbie
More
Piston ring interchanging #1
Another Yamaha newbe here. Can some tell me if mid 70s YZ400 cc rings will work on the same vintage and bore of a DT400cc?
20 Sep 2020 17:43
Swoop56
Site Supporter
Site Supporter
More
Piston ring interchanging #2
Check part numbers on Partzilla or similar site .
If they don't match , then probably not .
21 Sep 2020 06:04 21 Sep 2020 06:12 by RT325.
RT325
Collector
Collector
More
Piston ring interchanging #3
Welcome. Answer is, i don't know. Both will be 85mm or whatever oversize it is, & i'm pretty certain a YZ piston kit will work in a DT400 But so far as using rings of one onto the other the numbers are so far apart that i doubt they're a match. I had a YZ499D piston kit sitting on the shelf for many years & was a nice strong piston & well reinforces around the inner edge of the cutaway. I tried using it in my RT2MX 80mm cylinder but the fins nearly fell of boring it out that far--so was 'A Fail' lol.
www.babbittsonline.com/oemparts/a/yam/50...nk-piston-yz400c-d-e
www.babbittsonline.com/oemparts/a/yam/50...c7854f0/crank-piston
