Going Green
01 Mar 2020 09:03
mdscott
Site Supporter
Site Supporter
More
Going Green #21
Biknflyfisher wrote: Mark, saw this on CL just north of me in Fresno/Clovis.
Pretty trick, but so is the price.
I like your 1998 better than this one.....
Brian the Biknflyfisher
fresno.craigslist.org/search/mcy
Spent a lot on mods.
I need to get my shock worked on, the damping adjustment doesn't change.
Thanks Mark
Roseville, Ca.
'76 Bultaco 143 Frontera
'06 GL1800
'01 KDX220
'68 YG5T 80 Trailmaster
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
03 Mar 2020 22:02 03 Mar 2020 22:21 by mdscott.
mdscott
Site Supporter
Site Supporter
More
Going Green #22
Update on the 220
checked swingarm and shock linkage bearings, all look new(re-greased); installed new tires and checked wheel brgs. The PO drained tank and carb 7yrs ago when last used, both were clean. Sprockets look orig and almost new, a little rust on the chain. I’ll be changing fork oil, engine and coolant. Replaced all radiator hoses.
It’s apparent the bike was never disassembled, correct bolts all in the place, most have the factory lock-tite.
I think the tires may be the originals.
Yay2
Only issues are crack on the gas tank near the filler and rear shock rebound dampening doesn’t change turning the adjustment screw.
I’ll try plastic epoxy on the tank first, I have a rebuilt shock to replace the one in question
Thanks Mark
Roseville, Ca.
'06 GL1800
'01 KDX220
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
The following user(s) Liked this Post MarkT
12 Mar 2020 08:47
mdscott
Site Supporter
Site Supporter
More
Going Green #23
The KDX220 is done, sporting new FMF exhaust system, still goofing with the jetting. It will make it debut at Cal Dreamin.
Thanks Mark
Roseville, Ca.
'06 GL1800
'01 KDX220
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
The following user(s) Liked this Post MarkT, darinm
18 Apr 2020 18:22
mdscott
Site Supporter
Site Supporter
More
Going Green #24
Because California dreaming was canceled I decided to take the summer off and take a look at the piston. The KDX 220 has a problem with breaking pistons and I wanted to take a look. The piston was OK but the cylinder lining was coming off. I sent the cylinder to millennium technologies to have it re-plated. Also I had the machine shop shave off the cylinder head to get the squish area lower. It’s now at about .038”.
Thanks Mark
Roseville, Ca.
'06 GL1800
'01 KDX220
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
The following user(s) Liked this Post FrankC, Dirtboy
29 May 2020 16:19 29 May 2020 16:21 by mdscott. Reason: added info
mdscott
Site Supporter
Site Supporter
More
Going Green #25
I bought a Keihin PWK 35mm Air Striker Carb for my KDX220 to replace the standard PWK 33mm carb. Suppose to get give a little more top end and not really lose bottom end. Plus cures the jetting issues, basically from 1/8-1/4 throttle. By all accounts it's the hot ticket on the KDX-rider forum. The other way to go is RB Designs, but that route was more, and you still had to buy a new carb.
Thanks Mark
Roseville, Ca.
'06 GL1800
'01 KDX220
74 DT360
75 Norton
73 CB500K
63 C200
87 PW50
64 McClane Edger
The following user(s) Liked this Post t-bone
29 May 2020 16:51
darinm
Collector
Collector
More
Going Green #26
I hope you are only going to motorcycle race with that carb on it.
1972 Yamaha CT2 175
1972 Suzuki TS 185 Sierra
2016 Yamaha WR250R
The following user(s) Liked this Post Snglsmkr
29 May 2020 18:16
MarkT
Site Supporter
Site Supporter
More
Going Green #27
I had to go check my garage... looks just like the one I got for my Ninja 150RR... :)
Haven't tried mine yet, racers in Indonesia say it's the hot tip for the little 150.
The following user(s) Liked this Post mdscott, darinm
29 Jun 2020 22:08
YZBill
Sportsman
Sportsman
More
Going Green #28
I had a 96 KDX200. Only year they came with purple tank and shrouds. I swapped them out for an IMS tank and shrouds. Bike had the full Fredette racing mods and I won a B200 enduro championship on it.
The following user(s) Liked this Post MarkT, FrankC, Mountainsofbeer
