Steve F 1977 IT175D Resto
16 May 2020 06:19
2fishkev
Collector
Collector
More
Steve F 1977 IT175D Resto #61
Yamaha Motorcycle 1976 YZ125X Rear Wheel
Yamaha Motorcycle 1976 YZ175C Rear Wheel
Yamaha Motorcycle 1978 IT175E Rear Wheel
Yamaha Motorcycle 1980 IT125G Rear Wheel
Yamaha Motorcycle 1979 IT175F Rear Wheel
Yamaha Motorcycle 1977 IT175D Rear Wheel
Yamaha Motorcycle 1981 IT125H Rear Wheel
Yamaha Motorcycle 1980 IT175G Rear Wheel
Yamaha Motorcycle 1976 YZ100C Rear Wheel
Yamaha Motorcycle 1976 MX125C Rear Wheel
Yamaha Motorcycle 1980 YZ100G Rear Wheel
Yamaha Motorcycle 1981 YZ100H Rear Wheel
Yamaha Motorcycle 1977 YZ100D REAR WHEEL YZ100 E - F
Yamaha Motorcycle 1979 YZ100F REAR WHEEL YZ100 E - F
Yamaha Motorcycle 1978 YZ100E REAR WHEEL YZ100 E - F
Yamaha Motorcycle 1977 YZ100D REAR WHEEL YZ100D
Yamaha Motorcycle 1976 YZ125C REAR WHEEL YZ125C
Yamaha Motorcycle 1977 YZ125D REAR WHEEL YZ125D
Yamaha Motorcycle 1979 YZ125F REAR WHEEL YZ125E
Yamaha Motorcycle 1978 YZ125E REAR WHEEL YZ125E
Yamaha Motorcycle 1980 YZ125G REAR WHEEL YZ125E
Yamaha Motorcycle 1979 YZ125F REAR WHEEL YZ125F
Yamaha Motorcycle 1980 YZ125G REAR WHEEL YZ125G
This is the list from partzilla. I don’t know that it’s correct or not. Also cross referenced the hub and is the same for the 92 rt180d. Spoke set# 401-25304-20-00. Shows available for $92 on sale. :S
The following user(s) Liked this Post Steve F
16 May 2020 17:19
Steve F
Site Supporter
Site Supporter
More
Steve F 1977 IT175D Resto #62
Thanks Kev,
After much research I will use the spoke set you mentioned.
It is the same as what's used on 78DT175E.
Time to get my order together for rear wheel rebuild, more on this later as it comes together.
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
"And there ya have it"
16 May 2020 17:38
2fishkev
Collector
Collector
More
Steve F 1977 IT175D Resto #63
:likey
Hope they turn out! I would think so. Seems like finding OEM spokes requires a bit of sleuthing.
23 May 2020 17:20 24 May 2020 08:36 by Steve F. Reason: add info
Steve F
Site Supporter
Site Supporter
More
Steve F 1977 IT175D Resto #64
I scored another small victory today. If you go back to post #12, you will see that the rear axle was stuck in two places so was pretty much convinced that I wouldn't be able to salvage any of the spacers, but after looking at the prices of things I decided to do an experiment. I have alot of spare time & this project is not a priority to be finished any time soon. Long story short, I put the completely rusted axle ass'y in raw apple cider vinegar for a long bath/soak. I was able to remove most of the parts after cutting the end off a couple of weeks ago, but the spacer I need was still stuck. More soaking........:Coffee. So today while looking for some other parts to repair a mower deck I thought,"wonder how that's doing":?: I grabbed a couple of old bushings, a BFH, some WD & headed for the brick pile I use as a solid backer to hammer things out... To my amazement I got the thing to move 1st wack..:woohoo: so applied a little lube & continued to work back and forth till it came free...This will save me $22.00+shipping to use somewhere else..:woohoo: :woohoo: One other thing to mention, the junk parts, swing arm bushings & cut axle are now tools to use on something else.
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
The following user(s) Liked this Post MarkT, t-bone, 2fishkev
30 May 2020 13:17
Steve F
Site Supporter
Site Supporter
More
Steve F 1977 IT175D Resto #65
So while I'm waiting on parts a deep clean was performed on the engine in preparation for a more in depth inspection of things like the bore which requires a top off look. Seals will all be replaced, etc. Anywho, what I've discovered so far. A repaired/broken left case. Your thoughts are considered a valuable tool as I decide what direction to go on this. Run it or replace it.
The flywheel puller I have used on all of my projects does not seem to want to work on this one. Seems a bit weird.
Thoughts,, Is the 77 IT175D diff from all others to follow? I'll be looking at bike spec's on this...
Cann't wait to see what lurks inside the clutch side as this is way out of adjustment.
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
30 May 2020 14:37
MarkT
Site Supporter
Site Supporter
More
Steve F 1977 IT175D Resto #66
Flywheel threads are the same. It's a super fine left hand thread (I forget that sometimes and try to turn the puller the wrong way) :Ugh
Sometimes a small wire brush will clean up the threads enough... worst case is someone used a cheap puller and when the threads failed on the puller, it damaged the threads in the flywheel... That's why I cringe when I see people buying the cheapest puller on ebay... The good Motion Pro like you have is only like $4 more.
Sometimes it takes a little file or dremel work to clean up the starting thread a little... I've even had to grind out the first thread or two in the flywheel... use a magnifying glass and patience. Make sure you thread the puller in as far as you can even though it might take some time/work... I think it was RT325 that posted a pic of his puller where he ground out a relief to make it sort of a "thread chaser"... I've never had to do that but looks like it would work.
30 May 2020 17:03
Steve F
Site Supporter
Site Supporter
More
Steve F 1977 IT175D Resto #67
Thanks Mark, yes it is the same according to the manual.
Correct me if I'm wrong, it's the only left hand thread I have to deal with to get at the crank seals too?
After looking closer at it, I have some rust to deal with in the threads.
Will try getting a wire brush in there with my dremal for starters.
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
30 May 2020 18:05
MarkT
Site Supporter
Site Supporter
More
Steve F 1977 IT175D Resto #68
Good news. Wire brush might be all you need.
And yes, only LH thread that I can think of on the whole bike is the puller recess in the flywheel...
If it was a DT with mirrors, the RH mirror would be LH thread too... but that's it.
30 May 2020 18:43
2fishkev
Collector
Collector
More
Steve F 1977 IT175D Resto #69
You got me watching. The tension mounts.
Did you get those spokes yet?
13 Jun 2020 16:58 14 Jun 2020 05:00 by Steve F. Reason: add info
Steve F
Site Supporter
Site Supporter
More
Steve F 1977 IT175D Resto #70
Been side tracked, anywho I have started the motor tear down.
Appears we are on st'd bore: piston rough measurement is top @ 65.5mm bottom at skirts measures 65.6
No numbers stamped in top to indicate otherwise.
Bore rough measurement top 65.9 & bott. @ 66.0mm. Nice & clean....:)
Seems to be a lot of side play & angularity movement on con-rod, a .025" feeler fits snuggly in the gap. Need to look at specs.
wrist pin & bearing have blemishes.
Guess we'll send the top end off to Enduronut when I have a minute for evaluation and repairs.
I'm not sure on crank until I look at some specs, Who can service if it needs it?
EDIT: 14JUN am specs show AXIAL PLAY =.031/.079" (0.8/2.0mm) side clearance = .008/.028" (0.2/0.7mm)
thinking it needs to be serviced as side spec is very close to max ?
Will be hunting another set of engine cases with good bearing inserts. Thanks MarkT for your input & help on this.
Will be getting back to the wheels as this stuff is being planned & put in Que.
1974 DT250A
1974 DT250A
1974 GT80A
1977 IT175D "Alex'
1978 IT175E "Paul"
