78 DT400 Scratching sound when clutch engaged
31 May 2020 21:25
FrankieKingpin
Newbie
Newbie
More
78 DT400 Scratching sound when clutch engaged #1
Hello everyone, new member here.
I purchased a 78 DT400 a few weeks ago in pretty great shape. It really really well when I got it, guy basically did a mini restoration. However, a couple weeks ago I rode it to a local single track park, and when I got to the staging area I noticed a Scratching sound when the engine was running, but it went away when I pulled in the clutch. It still shifts and drives normally, but there is definitely a Scratching sound. It seems to me like something is loose. It doesn't sound like a bearing, like a squealing sound. Overall, it's actually a fairly quiet noise, and again, it only makes a sound when the clutch is engaged, but when I pull the lever it goes away.
Bike had only a few thousand miles on it. And the guy I bought it from mentioned he put heavier clutch springs in it, because stock ones are probe to failure?
I thought it may have been the screws in the clutch basket, but I did not see any evidence of Scratching on the case cover, and inside was very clean and with the oil.
Has anyone experienced a similar noise?
01 Jun 2020 06:11
Gr8uncleal
Site Supporter
Site Supporter
More
78 DT400 Scratching sound when clutch engaged #2
Welcome! to the forum.
Are you able to record a short video with audio and post it here? You'll need to upload it to youtube first and then post a link to the youtube clip.
Thanks.
01 Jun 2020 10:54 01 Jun 2020 11:05 by FrankC.
FrankC
Solution Contributor
More
78 DT400 Scratching sound when clutch engaged #3
Did you look for both thick spacer washers. I believe one behind the clutch hub and one behind the basket. Could also be a clip left off or mangled. At most parts sellers there are exploded parts schematics. Edit, give the basket a good hard wiggle, it has a bronze bearing I believe, no rollers. The clutch discs are clocked I believe the tabs spaced 60 degrees apart I would also check that the rivets holding the ring gear to the basket housing aren't worn and allowing the basket to move independently slightly.
